Three wire-ties with their tales sticking in three different directions every 18 inches silenced my mast. That includes VHF line to the top, a pair of wires for the anchor light and a pair for the steaming light. We laid it out on the ground then fished it in one run with an ancient electrician's snake collectively owned at the boatyard. I think I found that in Good Old Boat magazine. The local boatyard folklore says that foam holds moisture inside the mast and eventually adds weight in addition to adding to the corrosion load. The tie-wraps work fine and don't cost much.
Your tabernacle system sounds like a necessary evil that will be hardest on the VHF line. You might consider putting RF connectors in on either side of the section that takes the most wear and tear. That way you can just disconnect the worn wire and put in a new section. Lots of connectors don't help your signal but if done well don't hurt is as much as a total signal failure someday when you need the radio. Don't tell Uncle Sam but that's what a lot of us did in the army on field radio set-ups with wire sections that consistently wore out from being set up and taken down. We just cut out the beat up section, got four connectors and two barrel splices and patched in a good piece of wire. It carried traffic just fine. We made up a patch or two and were never off the air for long because of worn wire. If you assemble and solder them carefully you won't experience much signal loss and gain some security.
