Wonder what the equation is for a budget boat in relation to budget engineering? Also the Triton specs could be quite different from Ariel specs, as they are different from the A-30. (viz its 1" thick transom.)
It's pretty set here that the later Ariels Could have less layers of laminate tham the earlier ones. Perhaps the engineering progressed over the production run. The deck composit on 338 has a very sparse inner mat layer. We have only our personal experiences to go by. While the hull on 338 looks completely substantial and no doubt is engineered to be so, this amatuer believes that it is also entirely possible to rack the Ariel out of plumb. Especially if the deck is opened up.
Maybe the Ariel hull could be stood on a square inch point anywhere on its surface. All 2 1/2 tons? But I know that my cut water WAS 3/8"s
thick and so WAS the 'flat' areas of the keel. A lot thinner than the "bullet proof" scantlings we think these old plastic boats have. I'm led to believe. A whole lot of hull strength comes from Alberg's fully rounded curves. You engineer these surfaces (ie, make them skinny) because of the inherent strength of the compoud curve.
What damage might happen if you rammed your 2 1/2 tons into a submerged container at 6 knots? You know, or a log? Still, we all can agree that these Pearson hulls ARE very strong and aren't going to change shape on the hard, in the yard. Well.....is this true - or not?
But does Everett guarantee that when you remove large portions of the deck that the hull will not move at all? Or for that matter the unsupported deck/cabin mold? My amatuer assumption is that the entire package has to be in it's original engineered state, let's call it, for the engineering to be viable.
I'm not an engineer or a plastic boat professional for that matter. I will have examined every cubic centimeter of 338 by launch time. That doesn't make me an expert, it makes me weird, but a lover of the craft (pun intended.) So, when I look at Pearson:
338 may have been the pond version of the Miget Ocean Racer Cruiser that I assume the Ariel was marketed as. Because the unlocked, ungasketed cockpit lockers had only perforated hard board to keep contents from ending up in the bilge, green water in the cockpit could well have been a disaster for somebody in the past. This is an offshore boat? I don't think so.
I'm wary of marketing and engineering.
