Results 1 to 3 of 3
Thread: Mast/Boom Hardware Attachment- Corrosion
    Apr 2002
    Houston, Texas
    Can anyone give me the brief "how-to" on what kinds of screws can be used to safely attach hardware to the boom or mast? Worried about corrosion if its done improperly.
    Kent
    Stainless or bronze fasteners are ok. To minimise galvanic corrosion, however, use an anti seize lubricant on the fasteners.
    As for the hardware itself, it's recommended that you insulate it from the aluminum with an epoxly coating on it and the spar.
    Nov 2001
    You can either use sheet metal screws or machine screws. I prefer to tap the hole and use machine screws. In my opinion, the coarser the machine screw threads are the better - 20 better than 24, 24 being better than 32, because coarser threads are deeper.
    You are right to be concerned about corrosion. The screws you use will be stainless steel and the mast obviously is aluminum - a set up for disaster. The screws will lock and eventually break or pull out if not properly set with a corrosion inhibitor.
    You should use a corrosion inhibitor on the screw before being screwed in. On page 572 of the West catalog you will find "Tek Gel" What I have used is USS Tef-Gel which I got from West but don't see it listed anymore. Perhaps Tek-Jel and Tef Jel are the same. But, that is the type of stuff you should use, and it works fabulously.
  1. Deck hardware plan, and
    By c_amos in forum Technical
  2. Original Pearson Hardware
    By Bill in forum General/Off-Topic
    Last Post: 06-19-2007, 10:11 AM
  3. 12-24 Hardware or Search for the Holy Grail
    By John in forum Technical
    Last Post: 07-17-2005, 02:17 AM
  4. PEARSON HARDWARE
    Last Post: 01-11-2005, 07:15 PM
