Just now today we finished fitting the Schaeffer racing tracks onto the toerails of Adele M. We used the old threaded holes in the toerail, sort of , as not all of them lined up, and put washers and nuts up under. For the ones that did not line up, I redrilled them with a #7 drill bit and threaded them for 1/4-20 threads. I coated the threads with polysulphide caulk.
Bending was easier than I thought it would be. Started at the forward end, put in one bolt at a time gently bending the track to stay centered above the rail, drilling and tapping as necessary, and secured the end caps with 12-24 FH screws. The track is surprisingly flexible. Also put in a harken traveler, set on varying height pvc tubing stubs, which worked great.
