Results 1 to 15 of 83
Thread: jib track placement
Threaded View
  1. #19
    I try not to partially furl the genoa. The boat performs better with a reef or two in the main instead.
    My genoa tracks don't run forward enough for a partially furled genoa either. I've experimented with using a "barber hauler" made up of snatch blocks on a short line attached to padeyes on deck. (like the small picture below). This way I can use the same genoa sheets and still pull the sheet down and inside a bit when the genoa is partially furled.
    There is a pretty good general discussion on genoa sheet leads at the UKHalsey website with a few diagrams
    http://www.ukhalsey.com/LearningCent...clopedia5b.asp
    I'll reproduce it here in case the link fails
    UK-Halsey's Encyclopedia of Sails
    -- Genoa Trim
    Chapter 1
    Chapter 2
    Chapter 3
    Chapter 4
    Chapter 5
    Main Sail Trim
    Genoa Trim
    Sailing to Telltails
    Chapter 6
    Chapter 7
    Chapter 8
    Chapter 9
    Chapter 10
  1. Bilge Pump Discussions
    Last Post: 12-06-2018, 05:02 AM
    Last Post: 10-17-2004, 08:17 AM
    By Theis in forum Technical
    Last Post: 12-17-2003, 07:16 AM
