I have been reading this thread with interest especially since I have been sailing my Ariel for only 6 months and experimenting with different trim settings for the headsails. I have the original SS 30inch genoa track but the PO apparently removed the original jib tracks by the cabin sides. I have a CDI roller furler and have 2 headsails; 150% and 135%. CDI claims that I should be able to furl down to 70% of the original LP and still maintain a decent shape to the headsail although they recommend padded luffs which my sails do not have. In my case, I should be able to get the sails down to approximately 95-100% size. However, if the genoa blocks are not moved forward, I run the risk of the furler jumping up off the bearing and having a big mess to deal with. I wonder therefore, what modifications I should make to the genoa track configuration to make sure that once I furl down I can modify the trim to satisfy the smaller sail size. Can I manage a 100% headsail size with a longer genoa track or will I need to switch over an inner track by the cabin sides as originally set up for the smaller jibs? I feel it would be difficult to furl in and then have to switch the sheets to the inboard side of the shrouds but I am not sure what else would work.
I appreciate your thoughts.
Marcelo
