Results 1 to 15 of 16
Thread: Replacement Windows for Berth Portals
    bronze ports
    in the little search window up top here in the Off Topic Forum
    came up with a bunch of threads.
    Pertinent thread: WTB: Small opening port lights and, or, frame resource info
    also Replacing Portholes
    Once laid out the pieces of my original opening aluminum ports to foto.
    There must be 50 parts to each port. That's why they're expensive.
    Spigot(cutout) 8 x 4 3/16, Trim: 9 1/8 x 5 3/8. Curved ends are compass circles.
    SPARTAN (no catalog, no fotos) has flattened oval, like our original portlights.
    P586O (O for oval) 14lbs ! Cutout(spigot) = 9 1/8 x 6. Flange = 12 1/16 x 8. $400.
    DAVEY now has some nice looking TRUE oval portlights (the smallest size, close but
    not fitting the Ariel's flattened oval.)
    Spigot sizes: 8 x 5 1/4 --- 9 1/4 x 6 1/8 --- 12 1/8 x 7 1/4.
    Spigot is the mounting hole cutout.
    Flange that goes around spigot outside: 9 1/4 x 7 --- 11 1/4 x 8 1/8 --- 14 1/4 x 9 1/4.
    Weight of three oval opening ports: 7lbs - 8.5lbs - 15lbs.
    Smallest size with its more round shape will add about 6 more square inches of glass,
    and may take little to rework the original hole to fit the Davey spigot. Guessing.
    Inside, portlight has integral mounting flange that will match outside trim ring
    for thru bolting. Assuming, don't know for a fact.
    In the USA, the smallest Davey oval portlight priced $542 (R&W*).
    Have not seen these first hand. (Midsize $770, $200 over uk)
    R & W Rope --- Fisheries Supply (OOS but equally insane $$$) --- Rig Rite Spartan.
    (* this is a $142 mark up on the London price. Maybe lower cost if you import them!
    Ask what they weigh and if they include the bug screen.) My last overseas order, UPS
    took care of all the paperwork, and delivered to the front door. Should not have to
    pay the 15% VAT, which is often included in an online UK site.
    LATER UPDATE
    As of 6/2018, littlegull has Davey bronze opening ports. Maybe get around to
    a picture on the Gallery page. Ports are beautiful, but they are heavy weights.
    R & W Rope, when I was ordering, was the most reliable, and seemed to have
    direct connection to their source in the US. Screens, for example. Extra
    gaskets, still have to order, or improvise from McMasterCarr.
    Have to talk with Historical Arts, who may or may not still have the molds.
    They do not mention anywhere on site: marine/nautical.
    Would guess they will be as expensive, if not more, if they have to start from scratch.
    Aug 2011
    Walnut Creek and Sausalito
    Source for Pearson port light castings has changed to Port Townsend Foundry
    Aug 2011
    New Found Metals made this recommendation (below) for the berth portlights in the Pearson Ariel. Any thoughts about increasing the size? Original size (outside dimensions) are 5.5" x 9.0", they are saying I can go 8" x 15.
    "You have ample space to go with our 5x12 oval stainless. You cabin bulkhead looks a little thin so you can thicken it up by 5/8" by using our Teak Spacers. Our O512SS has outside dimensions of the frame at 8x15" . We have drill templates that assist in drilling our fastener holes in the right place (our ports bolt together) and will show where you need to remove any material. We can send you the template to be sure the port will work for you. A little larger port looks better on your boat besides adding light and more air." -New Found Metals Nov 12, 2019
    Richard
