Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 76 to 85 of 85
Thread: Commander 1964 Hull # 38
  1. #76
    Oct 2016
    New York Long Island
    What is more important to put on: Boom Vang or a Cunningham?
    Which will make handling the boat easier?
    Another question I have is about where the main sail comes down to and where does the goose-neck go on the Sail track--how high above the deck? I would think about where the main sail hangs at. But not if you want to have options when sailing.
    I have the mast goose neck connector thanks to Bisquit.
    Another question: At what point, when sailing along and I get a gust of wind, will the commander capsize if I can not dump the wind in time? Does the rub rail have to be under water, or can it be before that?
    I was a little scared sometime before I took the below picture.
    -joe
  2. #77
    If you don't reef in a brisk breeze you can sail along with the water running up against the cockpit combings Even in 50 knot gusts, we've never managed to broach the boat. Maybe if we were using a spinnaker it would be possible.
  3. #78
    Oct 2016
    Jib Location
    What is the correct location to put the jib? Somewhere inbetween or all the way to the mast head or all the way to the bow stem.
    It does not reach all the way. It is 18” from reaching the headboard.
  4. #79
    Oct 2016
    Cotter Keys—also called something pins?--and Turn buckles
    For the cotter keys that go thru the threaded rods of the turnbuckles on the shrouds and the two stays, what is the purpose: To keep the rods from un-threading all the way to the bottom (or top) and not going thru the female threaded parts, “OR” to keep the threaded rods from making a single turn. If one single turn, how is the cotter key left? Sticking out past the edge of the turnbuckle side?
    Tape wrapping of turnbuckles
    How does the tape get wrapped: All around the turnbuckle or something else?
  5. #80
    Oct 2016
    Position of the mast and the tension of the Stern and bow stays
    How to tension the Stays and Shrouds so they are not too tight or not too loose. Need a ballpark way of telling. Like, standing next to it, grab it and pull it to you. If it moves more than six inches then it is too loose. What is a good way to judge.
    Should the mast be exactly perpendicular to the water or leaning to the stern? I do not want to bend the mast for performance. That will be a couple of years. In general, where should the mast be leaning as related to Bow and Stern.
  6. #81
    Oct 2016
    Hi All:
    Please answer my newbie questions #76 #78 #79 #80.
    Bisquit answered that a Boom Vang is 1st thing to do before a Cunningham.
    Ebb: Your right! Slap on some anti-fouling and sail her! 3 times a week at least. Work 4 to midnight. Days are great!
  7. #82
    Joe, we've posted a note in the Technical forum on adjusting your rigging.
    http://www.pearsonariel.org/discussi...8107#post28107
  8. #83
    Oct 2016
    Thanks Bill:
    How to I measure the tension on the stay. All the force gauges are over $100.00.
    Any way that is trusted, but less expense?
    Thanks
    joe
  9. #84
    FYI - The standard Loose gauge can be found on the Internet for around $80.
  10. #85
    Oct 2016
    Hi Sailors:
    my question is, as a new sailor < 2 yearsd experience, is it better to learn on a fixed gooseneck commander or a sliding gooseneck?
    I have all the fittings and lines to go either way.
    It sure seems complicated.
