Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 107
Thread: C-025 Bisquit
  1. #91
    I'm aware I'm repeating myself, but you do terrific work and you saved a wreck of a boat and brought her back to life. Warms my heart!
    Those winch stands are epic. I missed the May posting of your nav station - which like everything else is top shelf.
    Cheers to you and Grace - GG is quite a gal.
  2. #92
    Oct 2016
    New York Long Island
    Your boat is so beautiful!
    Thank you so much for the hardware.
    For my next task, what is more important to put on: Boom Vang or a Cunningham?
    Which will make handling the boat easier?
    Thanks
    joe
  3. #93
    Apr 2015
    Chicago, IL
    No worries. I'm glad I could find a home for the piece. A vang will probably give you more ability to shape your sail in more conditions.
  4. #94
    Apr 2015
    Chicago, IL
    Fourth of July 2017
    Gail of Gail Grace Fame
    Name:  2017-07-04 14.20.04.jpg
  5. #95
    Apr 2015
    Chicago, IL
    Can Holders
    These are really handy and pretty easy to make. A nice addition to any Commander or Ariel. They just pop on the combings and you can move them wherever you like - inboard or outboard. All you do is run a piece of 8/4 mahogany stock through a table saw with a dado blade set a little wider than your combings. (it might take a couple of passes) Cut the top piece with a hole saw and a scroll saw and the bottom piece with a table saw. Clean up the edges with a router, glue the three pieces together with epoxy, a few coats of varnish and voila - can holders that look like they are original equipment. A made one large enough to hold a wine bottle and also a removable cockpit table.
    Name:  2017-09-22 11.26.02.jpg
    Name:  2017-09-22 11.26.54.jpg
    Name:  2017-09-22 11.26.36.jpg
    Name:  2017-09-22 11.29.39.jpg
  6. #96
    Apr 2015
    Chicago, IL
    Hatch Board Storage
    Here is one idea that solved several practical issues on my Commander: stairs to the interior; a seat for my new nav station; and storage for my hatch boards. I came up with a fairly simple plan that solves all of these issues. I made a box with a removable top to store my hatch boards. The box slides into guides screwed into the front face of the setees and doubles as the top step and a seat for me when I am at the nav station. The lower step drops into wooden brackets screwed into the setees and is easily removable. The box and lower step slide out so I can access the engine compartment. It works great and was pretty easy to make.
    Name:  2017-09-28 11.18.18.jpg
    The box and step in place with hatch boards stowed
    Name:  2017-09-28 11.18.38.jpg
    Hatch boards stowed
    Name:  2017-09-28 11.22.11.jpg
    The box removed for access to engine compartment behind stairs. Note storage for cup holders built into the nav station.
  7. #97
    Apr 2015
    Chicago, IL
    End of the Season
    Headed back to the yard up the Calumet River.
    Name:  2017-10-12 15.57.59.jpg
    Name:  2017-10-12 18.23.34.jpg
  8. #98
    Apr 2015
    Chicago, IL
    My commander has a wine cellar!
    Name:  2018-02-16 16.07.42.jpg
    I've been adding a few improvements to Gail Grace this winter. I removed the original sink when I added the cooler and the nav station last year. This winter I reinstalled the sink and some storage with a removable cutting board forward of the starboard bulkhead. Just for laughs I installed a wine/booze bottle storage area in some dead space port aft. I can access it from the cockpit and the port quarter berth.
    Name:  2018-02-16 16.08.30.jpg
    Name:  2018-02-16 16.08.40.jpg
    Name:  2018-02-16 16.08.13.jpg
  9. #99
    Apr 2015
    Chicago, IL
    More fun on Lake Michigan
  10. #100
    Apr 2015
    Chicago, IL
    Last Sail of the Season
    In good company at the dock awaiting haul out
    Nice sail to the yard
    (don't know why the image is rotated)
  11. #101
    Apr 2015
    Chicago, IL
    Another Season in the Books
  12. #102
    Apr 2015
    Chicago, IL
    Course Correction
    I decided to make a new rudder. The old rudder was perfectly fine however, the aperture was too small for the feathering prop I wanted to install. Also, I felt too much correction with the rudder was necessary in moderate to heavy air. I hate to mess with the original Alberg design. It is elegant and compliments the lines of the boat perfectly. However, I suspect my boat may have been delivered with a taller than standard rig. (Perhaps it was a Great Lakes – light air modification.) My P measurement is 1′ longer than than standard. Seat of the pants engineering led me to decide I needed to add 15% additional surface area on the trailing edge to help with the increased main sail area.
    Initially I planned to open up the aperture and scarf some wood to the trailing edge but this stared to look too hacked together.
    Abandoned Modification
    Back to the drawing board. remove the original bronze shafts and build a new rudder. Luckily I happened across a 6/4 x 24″ mahogany board that would allow a one piece replacement. It is a testament to the quality of the bronze that Pearson used that, after almost 60 years, when I removed the nut access windows, the bronze tie rods unscrewed like they were assembles yesterday. Once removed, I used an induction heater to heat up the upper shaft and bend it back 30 degrees to allow for the larger aperture.
    Next step is to make a template for the new rudder. I installed the new prop then made a Masonite blank and experimented with shapes that cleared the new prop, had the additional surface area, and looked like they belonged to this classic design.
    https://bisquitreborn.files.wordpres...419-copy-1.jpg
    Once I decided on a shape I cut the plank to the new shape, ran the leading edge through a router with a 1″ rounding bit to accept the upper and lower shafts, drilled holes for the tie rods, then using a 1 1/2″ hole saw made windows for the new nuts.
    https://bisquitreborn.files.wordpres...412_181048.jpg
    New rudder faired with nut windows filled.
    Next step is to install, coat with epoxy barrier coat and bottom paint.
    https://bisquitreborn.files.wordpres...4-1-copy-1.jpg
    On the boat
    https://bisquitreborn.files.wordpres...151-copy-1.jpg
    Barrier Coated with IP 2000 E
    https://bisquitreborn.files.wordpres...419_142029.jpg
    Bottom Painted and ready to go
  13. #103
    If your old rudder is perfectly fine, as you mentioned, would you be interested in selling it to me?? Lucky Dawg is in need!
    Kyle
  14. #104
    Very nice work, it does indeed look as if it could be OEM Alberg/Pearson.
  15. #105
    New rudder a gorgeous rendition. Totally impressed with your metal skills.
    Did not miss your marvelous cast gudgeon. Love your moody photos too.
    Here's to a 'Quiet reach' with your new rudder's tiller under your arm...
