hiya Capt. Tony.
I'm unsure what the dimensions of the two O-rings are as I can't read it clear off the specs. And I found an O-ring site by google but gave up for the moment because I didn't find a match in their lists. Will get back to it when awake.
3/32" seems right for thickness. The diameters must have to be pretty close as the rings won't stretch that good - the inside one against the shaft has to fit perfect.
Didn't think to ask P. Plastics if they could supply them or knew a source, I was just trying to get the rod and the rep (Larry) emailed that they could make the bearing. Right away took em up on it. Didn't shop around. Don't have wife to argue money with. Ordered two.
Will be prepared for 70 years of smooth sailing.
On pg 168 of the Manual can you or can anybody explain the double numbers used in the drawing of the bearing that designate the two grooves?
