I have not looked at the current model Yahamas, but my Nissan 6 hp four stroke has been modified by inserting a fitting into the flushing port on the bottom of my Nissan, and then hose clamping the hose barb on that fitting onto a Yamaha garden hose flushing unit from a model that they made a few years back. They may still be using the same unit now.
The Yamaha device is just a piece of hose and a cool little bracket that attaches to the housing of a motor. the Bracket his a female threaded garden hose plug. It is permanently mounted to my Nissan motor housing. All I have to do is remove the line from my gas tank, lift my motor with my Garhauer Lifting Davit, and while the moor hangs there out of water, remove the Yamaha flushing hose from its bracket with my hand and again by hand attach the male end of the hose on that unit to female end of my dock hose. Then with the Nissan 6 running (as per the Nissan operations manual), I run the motor until I run the motor out of fuel thereby flushing the motor and draining the carburetor.
The built in lifting eyes would be handy. I use a Davis motor lift that must be removed to check the oil. Its a snap to remove and a pain to reattach when the motor is in the well.
