Results 1 to 15 of 250
Thread: Outboard Discussions
    Dec 2005
    Tampa, FL
    Torqeedo Di Do
    (I find the Torgeedo site uninformative and unfriendly. Really peculiar if you are trying to sell something. And google has never heard of these folks!)
    Yeah, the website is obviously a computer based translation which loses some of that famous German sense of humour.
    The product is only two months old so that may explain the dearth of google entries.
    It is the cost and weight/power that are different from previous incarnations IMO.
    Probably could be used with a combination of a solar panel and the KISS wind generator from what I see on their site. Ah the freedom!!!
    Jun 2002
    Portsmouth, Virginia
    6 HP Nissan 4 stroke
    The Nissan 6 hp 4 stroke is all that I that have needed for my ol' Commander. It pushes the boat at hull speed, and I have had no trouble going against the tides and winds so far. The light weight (55 or so lbs.) is a plus at my age. Good fuel economy (about 1/2 gal. hr near hull speed) is also a plus. The only problem that I have had is the pot metal handles/leavers on the threaded screw thing-a-ma-jigs for attaching the motor to the transom. I broke one of the handle things with pliers trying to untighten them last year after a sail( very little pressure and one broke). The threads ,even though I keep them lubed with grease etc. corrode fast here in this salt water envirionment. Still this Nissan is a great little motor for what I payed for it four years ago. I also like the fact that I do not have to mix oil with the gas and there is no oil slick in the water when running. Oh, and it dosn't take any time at all getting it ready for the season, replacing the oil in the bottom unit and changing the oil;although, I have yet to change the water pump impeller which someone at the yard said should be inspected and or replace every year as it is made of some kind of rubber and may degrade even if not used all that much. One issue or dislike of mine is that it is not made in the USA but what is these days.I can't help but wonder why all of the big new sailboats have sail drives with all of the maintenance, leaking and corrosion problems. They are like having the bottom unit of an outboard motor in salt water all of the time...waiting for crab pots lines and whatever else that they strike to damage them. They don't make sense at all.
    Quote Originally Posted by Robert Lemasters View Post
    Does the nissan / tomatsu not have the optional rectifier kit abailable? I have one on my Yahaha 6, and it is nice to have.
    Jun 2002
    Yes, I suppose that I could recharge my batteries or provide power for my running lights with the motor running, that is another good feature with this motor. I have never had the need to do so, I have never run down my batteries. I have two deep cycle batteries that are recharged with a solor panel. There is an diesel motor I could get , If I wanted it (25Hp)for my Commander but the Nissan is all that I need. I would give it some real thought (the work and time) if I could get a small Yanmar cheap. I may with help, if I have the time and money and "she -who-must- be -obeyed's" ok, when I pull my Pearson 26, look into putting in that diesel. The 26 Pearson had a Merc 9.9 hp 4 stroke, and the person who I bought it from said that the boat needed that much hp to maintain headway when he brought the boat here (against moderate wind and tide).
    That does not seem to make much sense to me. The P-26 is a lighter boat.
    Maybe it cavitates being hung off of the transom vice being in a well?
    Dec 2005
    Tampa, FL
    Nissan 6
    If you get the x-tra long shaft (25") it comes with a rectifier for charging for an extra 100 bucks. I have been looking around for a spare as I have a Honda 9.9
    4 stroke that has charging capability, but weighs a ton.
    I have to switch over when I use my "shoal" draft boat for low tides here. It is a hard decked cat (Combo Cat - sail + outboard) that draws about 14" and gets going pretty quick.
    Jun 2002
    c-amos... Maybe the prop pitch on the Merc 9.9 had something to do with it. I have two props for my Nissan, I have the stock prop for a spare and another prop that I had the pitch changed at the shop(per Micheal Goodwin). The motor with the stock prop had about 1/4 or more throttle that did nothing, with the new pitch prop most of the throttle is now used for forward motion. The 26 Pearson is lighter, wider and higher, plus it is a fin keel, what that has to do with it all, I'm not sure.I will be taking the fellow's advice and use a 9.9 Hp motor, this fellow has three sailboats and has been sailing for 40 some years. He motored the 26 here, some 30 miles in a rain storm against an outgoing tide most of the way. I moved the boat when I bought it with the 9.9, I thought the motor had pleanty of power, but hull speed is hull speed. I like to think of prop pitch this way, like the threads on a screw,the more turns per inch...well you know.
  1. Outboard Well
