A338 has holes near the toe rail in the low point of the deck on both sides.
Inside there are short angled shunt tubes from the hole to the hull where half round tubes
go down to the bootstripe and exit. All built-in fiberglass.
It is a small closed system that does not allow water to enter the boat.
May want to make sure the shunts are glassed in well so that they won't leak.
Is it possible that a DFO tried to drill an exit hole up where the tubes touch the hull? This is not a good idea as deck water would stain the topsides.
