Results 1 to 15 of 422
Thread: Commander 147
    Aug 2008
    Camden, NC
    Jerry,
    As usual you continue to place the bar of excellence out of my reach. Very beautiful work your bestowing on Destiny! I have never worked with veneers, but know about quarter sawing and the pieces you veneered look fantastic.
    Your rate of accomplishment is noteworthy too.
    Question: In one of your earlier post of your potable water tank, I noticed what appeared to be cork sheet isolating the monel nickel tank with the hull. I know you added this isolator as it is not a Pearson touch. What is the actual material and did you do this to account for bit of slop between the tank sides and hull, as built by Pearson?
    Also, is that a plastic (marelon) water deck fill fitting with integral vent? I like the idea of an integrated vent, but wonder how well the material will hold up to UV?
    Respectfully,
    Chance Smith
    Chance
    Thank you for the complement but I for one do not believe working with veneer is out of your reach. You have the self discipline to do the job well. And small pieces like these are really easy to do. Large ones really require a vacuum press to get them well bonded without bubbles. These I was just able to put clamps around the perimeter to hold everything flat.
    Like your use of a roller to spread epoxy resin evenly I use a rubber roller to spread glue (Titebond III) to the surface of the plywood. Then I lay the veneer on top and a piece of waxed paper which is followed by a piece of scrap plywood. Then just clamp it up and let it dry. Really it is very easy.
    As far as the cork spacers you are absolutely correct that I added them. They serve two purposes. One as spacers to make the tank fit snuggly and two as a cushion to eliminate wear from the tank rubbing against the hard plastic hull. I used 1/4" thick layers of cork and contact cemented as many together as were needed (usually 2 but one location needed three) at each location to get the tank to sit solidly without movement. I also held them in place with contact cement between the hull and the cork.
    For the deck fill for my water tank I have attached another picture that tells the rest of the story. There is a brass or bronze cover (not sure which) that is chrome plated and it is the only thing exposed on deck. The marelon is all below deck with the exception of the very edge of the top. it is exposed around the perimeter of the chrome cap.
    Aug 2008
    Camden, NC
    Jerry,
    Great detailed photo. That was great foresight or is it insight, to isolate the potable water tank from making contact with the hull. Here's an off question for you. Have you ever used an oxygen displacer (like argon) to inject into the can of your favorite paint or varnish finishes before placing the lid back on? I just order a small pressurized can of argon to do just that. Don't know if it will help, but I hate getting that skimmed over hard layer from half empty cans of spar varnish.
    Respectfully,
    Chance Smith
    Chance
    I have not tried the Argon yet but it seems to be heavily promoted lately and I am planning on trying it soon. I will be interested to hear your comments after you use it.
