Results 1 to 15 of 422
Thread: Commander 147
    OK guys
    Even though I don't feel like I've made enough progress recently to post pictures, some of you are asking so here goes.
    The first picture is Destiny's water tank plumbed in. Laying on top the tank is the new deck fill fixture which has an intragal vent.
    The second picture is how I ended up changing the chain locker bulkhead. I plan to do enclosed storage above the v-birth (where the shelves are) with doors that have cane in the center for ventilation, so I needed to shrink the hole going into the chain locker to do that.
    The third picture is what the main bulkheads look like from the v-birth side. The v-birth is completely tied back into the bulkheads and you may notice in some of the other pictures that I changed the direction of the vertical plywood that supports the v-birth in the center. It used to be one straight piece and the drop in center cushion had to span a pretty wide area. So I made it bend and go more straight back at the aft end of the platform for the porta potty (or head as the case may be) which also gave me a larger storage area under the v-birth sides.
    The forth picture is the sink cabinet with the first coat of primer on it. If you look closely below the cabinet and aft of it you can see what looks like a mouse hole in the quarter birth. This is where the foot pump for the sink's water supply is installed. Also you will notice some screw holes near the round outside corner. The entire end of the cabinet is removeable for clear access to the plumbing below.
    The fifth picture is the stove cabinet.
    There is one more picture that I will have to post in another post (I maxed out on pictures in this one) showing some of the mahogany pieces that will go inside the boat.
    Pictures continued...
    The picture below shows some of the mahogany pieces that will go inside the boat. Most of these go in or on or near the two cabinets. I'm currently working on 6 more pieces that below to this group and then I need to make all the parts for my electric panels.
