Results 1 to 15 of 422
Thread: Commander 147
    Apr 2008
    Forsyth GA
    Looks good Jerry, When I do deck work I bend the balsa core over a piece of large PVC pipe and wet out the scribes in the balsa. In my mind I think it will make the deck stiffer and if it should leak at some time in the future it will slow down the spread of water. Do you see any benefit to my method? Yes it is a great time of the year to be doing this type of work, that 100 degree stuff was just too much.
    Carl
    Thanks for the tip, I can see how that would be a benefit to the final product. I did have epoxy wick up through the core and stick my fastener boxes to the deck so I probably got some of that with the way I did it. But your method does make sense to me so I will try it on the next section. This really is a learn as you go process for me. I've never done anything like this before. I think I will want to do small areas of core at a time with your method because I would be concerned about the epoxy starting to kick before everything was set in place correctly.
    Apr 2008
    Forsyth GA
    Your Welcome, I have never worked an area as large at one time as your doing, Working alone on that large of an area means you certainly have to have everything laid out perfectly to come within the kickoff on the Epoxy. I recored the coachroof on my Electra and set too much weight on it and bowed the roof in on both sides of the hatch. That sure caused a lot more work than I originally planned on, so I understand learn as you go very well.
    Carl
    I've been treating the epoxy work a lot like I do my woodworking. I always do a test clamp up when I glue up wood projects and use scrap pieces to test a tooling setup. So I always do a dry run for an epoxy layup also. I find I get better end results with less time (and money) invested by following that discipline.
    For this project I only mixed 18oz's of epoxy at a time. I poured it straight from my mixing pot onto the deck and used a roller to roll it out. After each layer of glass was wet out I used a thin finned glass roller to roll out any bubbles in the material and then started all over again with the next layer. It went surprisingly well.
    Aug 2008
    Camden, NC
    Jerry,
    Simply EXCEPTIONAL! Your recore process on Destiny's Port and Starboard quarters are some of the finest I have seen. You continue to impress me with your high caliber work, attention to detail and craftsmanship! Thank you for imspiring others to attempt to do as fine of work as your bestowing on your beloved Commander.
    Respectfully,
    Chance Smith
    Chance thank you very much for the kind words. I try hard and it's nice to know others appreciate the effort I'm putting into Destiny to make her the best she can be.
    Well as of today the first area of the recore is ready for high build primer. After the paint goes on nobody but me and all of you here will know she was ever tore apart and put back together. Now it's on to the next area.
    Here is a trick that worked like a champ
    While doing the second area of the recore and at a point where I needed to mix up some thickened epoxy anyway I decided to do the cutout for the water tank deck fill. I was pleasantly suprised to find solid balsa in this area but that meant I needed to figure out a good way to dig out the balsa around the perimeter of the opening back approx 1/2" so the screws holding the deck fill in place would not be in balsa.
    I came up with a slotted cutter on the trim router that worked like a champ as you can see below.
    The last picture is the area I'm currently working on.
