Results 1 to 15 of 422
Thread: Commander 147
    I think the shape is perfect. I like how the handle end droops down so it becomes level when installed.
    You probably wont find a stock tiller shaped like that. Usually the handle end points up. Not terrible, but it could be better. The drawing is helpful, and H & L could build one based on that for the non-carpenters here
    The worst is a tiller that is too low. Not only do you bang your knee, you end up having to lean over while steering. Becomes uncomfortable
    Nice job
    Thanks Commander Pete...
    I'm not sure who H & L is but I'm guessing they could build it cheeper than I could because they probably have a lower cost of materials and labor.
    Not counting the time it took me to build the jig or make the template I'm guessing it takes me about 6 to 8 hours of labor to make one of these. By the time I set up the bandsaw and resaw all the strips and surface them in the planer, then glue everything up and shape it afterwards and sand it I would not be surprised to have that much time in it.
    Jerry, I believe H&L build replacement tillers for just about any boat, and have in stock or patterns for any one design.
    I sent them a pattern of my own, and of course more radical than any they show on their web site.
    Thought they would find a close match to a set up they already had. But I got back was a beautiful and exact laminated tiller of the pattern I sent, rounded and sanded for about 70 bucks.
    There are no glue lines in what they do, so I suppose they use 'plastic resin' glue
    the mix with water powered stuff. Traditional for glue up spruce spars, imco. It's water resistant. But you hardly ever see one of their varnished tillers delaminating. Except down at the tillerhead where the bolts are and people forget to juice the holes through the wood.
    Thanks Ebb
    I just did a search and found several people selling their tillers and they were advertised between $60.00 and $100.00 based on the exact tiller you wanted. A very reasonable price based on what I know I have invested in mine.
    Nov 2009
    Brooklyn, NY
    Quote Originally Posted by Commander 147 View Post
    Jerry
    Most likely H & L isn't making any money building tillers. At such a low price they are attracting customers with a classic "loss leader" item. I'm sure it's also a way to get rid of leftover scrap materials and keep employees busy. Something more complicated than a tiller from them will no doubt have "market" pricing.
    I make cutting boards out of my leftover scraps mostly as gifts for friends and customers.
    Ben
    Spent the day working on Destiny today...
    And the pictures below show why you don't use polyester resins to tab in a bulkhead. The first picture is what somebody did for the previous owner when he replaced the bulkheads. It was coming loose and when I pryed on it a little it just popped loose which you can see in the second picture. I had to cut it loose from the bulk head so I can redo the tabbing.
    My current project is repairing and reinforcing the bottom side of the deck where I will later be recoreing from the top. After patching all of the holes I will be putting a layer of 1708 biax and a layer of 6oz finishing cloth on the bottom of the deck to give it more strength before I cut into the top. And once I had talked myself into going to all that work I decided I would fill the toe rail so I could tie the hull and deck together and make a better looking job of the reinforcing. The third picture is a drawing of what I'm doing at the toe rail.
    Hey jerry,
    To stick heavy mat to the overhead you're going to have to figure out a way to hold it up there until it sets. I don't know what.
    But it occurs to me if you have to go to the trouble of supporting the cloth with thick cardboard and a miriad of battens to hold it all up there....
    why not skip the catortionist wet matt stuff and just support the deck with just enough pressure on the underdeck from spring battens to support recoring the deck from the top.
    The argument would be that you are probably going with closed cell pvc foam and epoxy and glass. The green foam I've used has to be considered structural. Marvelous stuff.
    You will end up with a very strong composite. Stronger because epoxy sticks better to the foam than it does to end grain balsa.
    On the Ariel the foredeck has a plank of plywood down the center from the stem to the cabin. No balsa there. And probably no rot because I found the stip had been isolated from the balsa. Effectively separating the balsa into separate islands. If you are replacing that you could do first one side then the other. You could do the same along the side decks. You'd just make sure you married the sections together real good where they meet.
    Glass matt, while very strong, soaks up an extraordinary amount of epoxy. I haven't done it but imco the stuff will be too heavy to stick to the roof, it'll want to pull away, so it will have to be supported everywhere. However, I think you could get away with pasting 6oz glass cloth overhead. Cloth would allow easier filling and fairing too.
    TOE RAIL
    Filling the inside of the toerail will take a huge amount of expensive epoxy. I know - I filled A338's toerail stem to stem. What's that, 52 feet of 1 1/2"X 1 1/2"X 1 1/2" of fill? Plus waste, squeeze out, and pot life fiascos!
    I 'cheated' by jamming one foot long pieces of wood up in there with lots of epoxy gel reinforced with chopped strand. The wood was milled to make a flat bottom inside easy to fair with the deck. In some places you'd never know the hollow toerail was ever there.
    Using wood chunks cut roughly to fit could be jammed in the cove and the squeeze-out cleaned up easy because the pieces didn't need to be braced or fastened.
    Now there is more wood than plastic inside all along the cove which makes it very friendly to screws and thru-fastenings anytime later.
    Just ideas.
    Ebb you know I appreciate your ideas...
    One of the best parts of having this forum is that it offers us the chance to bounce ideas off each other. Many times other people will bring up points you have not considered. That seems to be the situation here.
    When I use 1708 biax my procedure has been to wet out the area I want to apply the mat to then wet out the mat on both sides working the epoxy into the mat on a flat surface. Then I pick up the saturated mat and apply it to the surface I'm woking on rolling out any bubbles.
    Now here comes the part (being honest) that I had not considered. I have not had any problem with the mat sticking to a verticle surface when I applied it. So I had not considered that it would not stick to the bottom side of the deck. And your point seems to be a valid concern.
    Being a bit hard headed once I have committed towards a course of action and since you say you have never actually tried it yourself, I think I'm going to try a section in the bow in the chain locker area. If I have to grind it back out in there and do something else it does not matter as much if it is not as attractive of a finish.
    The side of the hull and to a much lesser extent the bottom of the deck both have a lot of bumps and hollows in the glass work. I had already assumed I would fair those areas out with thicked epoxy before I apply the mat. I wanted a nice smooth surface to make it easier for the mat to stick to it without bubbles and hollow spots.
    BTW Ebb, you will be happy to hear that I am no longer using West System epoxy. I found Raka non-blushing epoxy which seems like it wets out better also. Certainly a lot cheaper and it has a good reputation on the plastic classic forum. The other thing that has been mentioned about this epoxy is that is seems to cause less reactions for people like me who are sensitive to it.
    As far as the toe rail goes... my thought pattern went something like this. It is my hope that someday one of my grandchildren will take up sailing and then ownership and care of Destiny. As a matter of fact that is one of the things that drew me to the commander. I wanted a large enough cockpit so I could take my family sailing and we would all be able to sit in the cockpit comfortably. So I wanted something that would never be a problem down the road. And since the rubrail is screwed into this area it was conceivable to me that over time water could get in there and cause the wood to rot if I put wood up in there. Granted it would take a very long time and likely not occur in my lifetime but possibly in my granchildren's. So I wanted somthing water would not affect. I talked to the folks at Fiberglass Coatings in St. Pete and we came up with a polyester putty that they developed called FC8 that is thickened with microfibers and silica that would fill the toe rail area. I'm not asking it to do anything structural I'm only asking it to fill a void that will be enclosed with epoxy wet out fiberglass. For $90.00 I got a 5 gal bucket of the stuff that should be enough to do the toe rail. Then not being one to just take some salesman's word for anything I mixed up a pint of the putty and put it on a piece of plastic that would allow me to get it off in one piece. I wanted to see how strong the stuff was. The putty was about 1/2" thick and when I tried to break it I could not do it until I supported the two ends and took a hammer to it. Then when it did break it broke cleanly into 3 pieces and did not just shatter. Take a look at the pictures below.
    Here is a link to the website.
    http://www.fgci.com/
    Jerry, The whole thing for me too has always been feedback.
    We are engaged in Discussions here
    - sometimes not much
    sometimes too much
    - but always with the thought that anybody can join in
    - or read and move on.
    The most marvelous thing about the internet still is that it is about information,.
    every kind, not just product info.
    I've been taken by product hype so many times that I, if I remember to, feel that research, product and other peoples experiences are necessary before I dive in.
    This is about that.
    Be interesting to hear about your experience with RAKA epoxy.
    I also hope you record for us how the rail cove filling goes. Using inexpensive polyester filler seems OK [VENT THE FUMES, they are toxic], but we have to assume you aren't expecting a bond and that you probably will seal the upgrade with, I don't know, light fiberglass fabric and epoxy.
    Given the age of our boats a reinforcement of the deck-to-hull seam seems like a good idea also. The seam is just about where the end of the fill will be if it is faired with the bottom of the deck.
    Really enjoy the exchange and your photo journal.
    Without question the ability to share photos, insights and experiences with others makes this classic plastic website
    THE BEST on the planet!
