Results 1 to 15 of 422
Thread: Commander 147
    Testing...testing...123
    Well, I finished putting the 20 layers of carbon fiber on the bottom of the beam and two more layers of mahogany after that. The beam is almost done fabricating. In addition I made the two bulkheads that will support the beam. After I take a little break and post this I plan to go back to the shop and cut the slots in the end of the beam that the bulkheads slide up into. Then it is one more dry fit test to make sure everyting will assemble correctly and it will be time to mix some thickened epoxy and glue the beam up to the bottom of the deck. After that is done it will be time to tab in the bulkheads.
