Results 1 to 15 of 422
Thread: Commander 147
    A peek at what Destiny's DC fuse panel will look like...
    I took the time (when I really should have been doing other things) to work on Destiny's electric panel area this weekend. I have always disliked how boat builders put the smallest fuse panel in that they can get away with on boats. Today we have a lot more electronics than we used to in addition to the normal stuff like lights and power outlets. In addition I like dedicated breakers for each electrical item. With this setup I should be able to have dedicated breakers for everything and and 3 or 4 left over for spares.
    The panel is hinged to allow easy access. To the left of the panel is where a 110VAC outlet will be available for use when at the dock in plugged into shore power.
    The two frames I made for the panel I made as mortise and tennon frames as you can see in the first picture.
    The second picture is a mock up of how it will look later.
