Some of the recent progress on the glasswork
First some time ago I decided to glass in the end of the ballast like Mike (Commander 227) suggested. My reasoning went like this. Unlike a boat that has no foam around the lead ballast that can drain easily to the empty back end of the keel, Destiny has foam all around the ballast and this foam sucks up water and dosen't let go of it. So I thought it better to try and keep water out of that foam by sealing the ballast in fiberglass. If water does get in that area what ever will drain out can go out the plug the prior owner had installed in the bottom of the keel when I pull the boat at the end of season. The first picture is of that job.
Next like most commanders the reinforcement for the backstay chainplate was very short. It left the top 8 inches of the chainplate unsupported. So I cut out and glassed in a new reinforcement for it to bolt to. The new one allows me to cut in half the unsupported distance of the chainplate. Also It is twice as thick as the old one. The second picture shows the old reinforcement.
The third picture is of the new reinforcement.
The 4th picture is of the glassed in new reinforcement showing the added bolt 4" higher than was previously possible. It also shows a couple of backer plates I glassed in for the hinges on the lazarette hatch. I glassed in several backer plates in this area but since I'm out of pictures again I will show you all those at a later date.
