Kent,
There are other fun foam sheet plastics, one of which is Ethafoam.
It is a translucent closedcell bendy polyethylene. BUT we can't glue this more friendly foam to the hull.
Possibly there's a glue by now that we haven't heard about yet. It's way cheaper than ensolite. Used as packing material for shipping.
Requirement may be that the surface of the sheet be pretreated with a propane torch to change its 'surface energy'
and then stuck on with a nice acrylic 'yogurt' paste. Haven't tried this myself !
Armacell also produces wax plastic (polyethylene p.olefin) insulations. They may have a waterborne mastic that sticks it.
NO aromatic solvents, OK? !
Ask the Armacell tech about gluing in the foam insulation he recommends
if it's not an ensolite.
The CLOSED CELL insulation must be firmly attached to the hull. Bonded.
Once it is embedded and bonded, no condensation will form and a good waterborne paste won't be a problem. If it's not continually immersed.
Ensolite in most ways is ideal because it conforms to mild concave surfaces. When gluing in, pushing it against the hull will keep it there.
This means the sheet won't tend to pull back into its flat sheet form (OR create a bulge) when gluing to the hull.... like other less docile foam materials. It's what makes ensolite the only closedcell foam that is also comfortable for expensive flotation cushions and bunk pads.
Also want the glue to bond to the rubber. It's possible that even regular contact cement can be pulled off the foam. Observed this once, it's not something I would swear to.
White carpet layer's paste is something to look into to. Acrylic glues are a minor miracle of sorts. See post #10, APAC 564.
(Defender & others have a liquid waterproof capet adhesive - not described as a paste - tech data sheets seem unavailable at any source. The origin of the carpet adhesive is Redrum Fabrics (makers of Nautilex marine fabric glue). Billed as non-hazardous. It works by
water evaporation in application, like 564, and other waterborne pastes. Forum user complains of material not holding on vertical surface.
Defender - Marine Carpet Adhesive - (Redrum Fabrics)Maple Leaf K-Grip 398, $34.99gal. Waterproof after cure. Is this roller or trowel???
[ I have the acrylic paste and the ethafoam, maybe I should do a test??? ]
You might be persuaded to use tube polyether or polysulfide. (Imco these structural adhesives, including tube urethane are WAY overkill) you'll still have to spred the material with a toothed spatula same as the yummy waterborne stuff - to get total no void coverage - and on both surfaces! Cost hundreds of dollars, and the cruds are viscous and messy to use.
There are no marine tube synthetic rubber caulks that will glue HDPE, polyethylene foam.
__________________________________________________ __________________________________________________ _______________
[ Be warned and do your own confirming/testing. So far as I know this method is not supported by public forum. Nor Nigel, Larry, Maine or Don. Nor PracticalSailor or GoodOleBoat.
Personal research and luck (good & bad) led to the method, which seems logical.
And the inside of litlgull seems sucessfully insulated - from sheer to more-or-less waterline - with ensolite and a fine non-toxic cork&carpet paste.
This is.... in my considered opinion. ]
I got my sheets of Armacell Armaflex after visiting with their distributor in Houston. They said it is the best foam they have for enclosed areas and is used in school HVAC systems. I got 1/2" 36x48" sheets. I also sourced some white vinyl cloth and glued it to one side of each sheet. I tested cutting the sheet with the vinyl using scissors, regular knife, hacksaw blade, box cutter, and electric carving knife. The carving knife was way way superior to the others. Cut like butta! I made patterns with brown paper, and transferred to the sheets. Cutting them with the electric knife was soooooooo easy. Very clean edges, no tearing. I looked at the adhesives, and I decided to take a chance with the 564 enviromentaly friendly adhesive you used. No way do I want to use volatile death chemicals in the cabin. Also, the ability to slightly move the pieces during installation is a selling point versus contact cements. I don't know how I'd get a piece positioned properly with contact stuff.
There is a 564 distributor in Houston so I was able to just pick the stuff up. It cost me $70 for a 4 gallon pail. They don't carry 1 gallon containers. Guess I'll have a lot left over to glue AstroTurf on the decks of my boat and at least 10 others at the marina. The three women at the 564 distributor are into cats (the animals,not the boats!) and tried to get me to adopt one of the kittens that they find from time to time in their warehouse! One kitten sat on the keyboard while my order was being entered. Explains the typos on my invoice! I'll let you know how the installation goes. So far, so good!
I decided to apply the vinyl before cutting and installing, as the prospect of doing the vinyl after insulation seemed beyond my skill or patience level. I'll glue the seams, then stick on a white batten from Lowes using a 3M product for vinyl surfaces. The way I cut the sheets left me with only one seam in each cabin. I don't think that's too much of a distraction!
But I haven't tried to do the pieces for the roof of the V berth yet. Did you do that area and if so, how did you splice the pieces? Looks like several ways to do it.
Kent
Sorry to chime in late but I wouldn't recommend the HVAC insulation Armacell or Armaflex as they will hold water. I am an HVAC technician by trade for 30 years now and I've seen it first hand. If I were you I would go with the thin sheet foam Ebb suggested and put it in with Vinyl Mastic made by Polyken. It comes on a 2 or 4 inch roll like duct tape but its thick with a removable backing and strong sticky but do your install in warm or hot weather to insure the bond. and theres only the mess of the backing to clean up and alot cheaper than liquid adhesives or epoxy .
Commander 5
