Results 1 to 15 of 69
Thread: The oft discussed outboard extra ballast revealed
    this little piggy
    For the record,
    A-338 came with a form-fitted 120# pig with an iron ring in it exactly like the rings I cutoff that were sticking out of the 'encapsulated' ballast. It is shaped like Mike's (post 37) to fit right behind the end of the glassed-in ballast in the bilge.
    Somebody must have really hated this little piggy because there are a bunch of hammer marks embedded in the S.O.B. top!
    __________________________________________________ __________________________________________________ ___________
    The pig is 9" long - 7" tall - and 6" wide at the wide end.
    Bathroom scale weight - 120#
    A cubic foot of lead comes in at 708#
    A cubic inch at .40969# at room temp.
    Getting an estimate of the weight of the added pigs doesn't help with the curve of the bilge, does it? But maybe you could ballpark a guesstimate by averaging the angle at 45 degrees.....?
    Wonder what I have under there.
    Its all glassed over and looks like a shallower bilge than 227
    This picture was taken from underneath the stern-most floorboard looking forward
    http://pearsonariel.org/discussion/a...1&d=1142982282
    that's curious.. A-231's bilge looks equally shallow, but my lift rings are on the centerline. it would be interesting to get some measurements from the bilge to the floorboards on a couple boats to see how similar/different they are in profile.
    it might take an xray or a thermal imager to know what is really down there without breaking out a saw.
    Those rings are likely attached to the main external ballast located in the keel.
    Nov 2002
    sure looks like what I have in Commander 270. Mine has an extra layer of glass laid over it and is nicely painted by previous owner.
