I don't think I posted anything on the sea hood in a while.
Here's a 'dry run' with the new hatch to check for clearance. The dash board needs a little sealant to hide the outer seam and the display heads will add a touch of realism also.
Maybe I should have taped the covers up there for the picture?
Had a tough day working. Every hour or so I had to run outside to see what was flying overhead. The local air museum is having a WWII exhibit. B-17, P-51, Corsair (love that plane) and I think the Zero even took to the skies. Wow!
Way back when I joked about shag carpet and curves. Well, the shag might not happen. I thought I'd try to make our own plywood today. What the heck, if you're going to make plywood you might as well make radiused plywood, huh?
We knew we'd need a 24" chunk and at least a 33-36" piece too. So I thought I'd make a jig that would pull a double duty. It forms a 2 1/4" radius (in theory, that is) by pulling 1/8" plys into the jig using pipe clamps and heavy walled 4" PVC. The 24" piece is setting up now as I type. Maybe tomorrow we can slow down enough to get an action shot.
..aint much of a cameraman!?! Why Pete, I've been very fond of a number of the photos you've posted deck hardware and nav aids to name a couple.
We're pretty lucky to have the Fargo Air Museum close by. It's not a big facility by any means but the owner/curator has a heck of a collection. Including a super corsair, one of eight remaining and the only one flying in the world.
Anyway, this is a sailboat site...
We're going to use the curved sections in the galley. The shorter piece will form the inboard corner of the ice box. That's right, I said ice box. Well, ice box/navstation/com. center. The longer of the two will form the inboard corner of the galley proper. Those two rounded corners should save alot of shin skin.
After seeing the radius I with I could find some teak veneer fast. I'd really shoot the wad on the main cabin. But as it is, it'll probably be painted white to open things up a bit. Maybe we'll put raised panels in the 'salon' to add a touch civility.
