Results 1 to 15 of 619
    Quote Originally Posted by mbd
    Tony, I had an idea looking at your picture - how about an aft berth tucked up underneath your cockpit? Look at all that room in there! Then you could use some of the v-berth space for an enclosed head.
    I've been thinking the same thing. I'm glad I've lived aboard for a while before doing any major work in the cabin. My design is evolving.
    I know what I want to do in the v-berth (guest bunk on one side, cabinet/drawer stowage on the other), and the settees (somewhat). The back wall area of the cabin is what I've been pondering for the past couple weeks. What I do there will to some degree determine what the final arrangement of the settee area will be. A quarter berth tucked up under the cockpit (basically extending the current berth ~2' aft) makes a lot of sense - it puts a usually empty, but needed, area more into the stern of the boat, would provide a flat floor to the cockpit locker above, and will be a safer place to be bunked in stormy conditions, especially if, heaven forbid, repeated knockdowns or a complete capsize were to happen.
    I did consider using that area right under the cockpit floor, but I think it would be too hard to keep dry, especially being right under the companionway. As I write, this thought comes to mind: if done properly this area could be made1) watertight and 2) detachable, thus being able act like a liferaft if the boat started to go down. Kind of a James Bond liferaft. Maybe whoever has Ariel #007 could do this. Know of any sources for explosive bolts?
    PS. BTW, this can't be said enough: VERY slick work!
    For sure! Kudos!!!
    Water tight and detachable! I gotta see a drawing!
    A bunk under the c-pit was seriously considered here. But that would require some serious rebuilding for supporting the cockpit sole, don't you think. Couple with that, as Kurt pointed out, it could be a very wet area.
    Quarter berths tucked on one or both sides like Ebb has done are alot easier to accomodate. If we just had another 4-6 feet we could do something on the order of this...
    Aha! Found it!
    Here's the pic of Ebb's under-cockpit quarter berth.
    From Ebb's Thread. (Can't get these images to show up for some reason, just the links to them...)
    Dang it. I'v gotten used to sleeping on the *port* side, but this berth with Scott G's ex-icebox-lid illumination (see the Association Manual and/or Scott's page ) would make things bright and cheery even on an overcast day. I've an old, huge bronze opening port that I considered mounting in the cockpit footwell sidewall for light and ventilation of the quarterberth foot area, it's something to consider perhaps with a version of Scott's mod, just on the other side. My current idea-ing is to put the icebox below where it currently is, a' la Scirroco...
    Tony, that's an awful purty quarterberth and nav station. The compass rose inlay is gorgeous, and salty looking. In fact, everything in that pic is nice...
    Kurt
    An opening port would help out a lot for anyone slightly claustrophobic in one of those quarter berths. I'd definately make a cover for the x-icebox hatch lite. Just think of a wine hangover with the sun beating in on your eyes. YEEH!! I just made the room spin
    Nothing stellar tonight. I guess I'll just keep making pieces for the puzzle next spring-unless we get some really crazy weather. for which, I'm ready to lay some glass.
    As things come together some things are working out fine and others...
    The ice box/nav station is okay as is the galley. They are pretty much a straight forward installation. Then there was that little bureau on the forward end of the starboard setee. I didn't even plan on that one, it just sort of 'came together' the other day.
    The port side setee will have a berth that tucks under the galley giving a desperately needed six and a half foot spot for yours truely. That sill leaves 8+ inches for a water filter and misc. plumbing and 'stuff' storage.
    The problem I'm running into now is coming up with storage behind the setee backs and still having enough room for a double berth across the main salon. If I was only addressing sitting room it would be a piece of pie( ) but I need those 3 inches on each side.
    I'll have to hit the books over the next few days and try to come up with something. Unless one of you guys has the right idea.
    Tony,
    Those curves ARE gorgeous, can already tell the interior will be fantastic.
    Yesterday, sitting below, while taking a break from prepping the toerail, pondered the double berth quandry. I have to go for even more length, width as well.
    Remember your cushions will raise the level and create width for sleeping.
    Could make the seat backs part of the double bed expansion with the bedding behind on one side (338 will be starboard.) Could make one settee back without vertical partitians - still with the shelf on top - gaining more horizontal area to the hull. Could even pad the hull.
    [I've almost convinced self to raise the sleeping levels to the height of the V-berth on 338's starboard side in the saloon!!! Aesthetically dangerous! But I am putting in a two seater dinette with a table that can be hinged up to get it quickly out of the way for the sleep mode. Dinette seats same height as V-berth. Raising up the platform means maximum width for lying down and more precious stowage.
    The double would take all of the aisle, of course. In my case there has to be like four square at the companionway to take care of any vertical business. Would sit on the bed with feet down at foot of ladder. Will design ladder that can be pushed under bridge deck. Hopefully the commode between the V-berths is accessable. But privacy and convenience would be better served with a camp commode out in the cockpit when the cabin is double berth. imco
    The thing about the quarterberth that Alberg has in the Cape Dory is that it is an enormous volume. I imagine it will be the sail locker on 338 (because I've put the platform low as possible) as the bags can be stood up into the usually unavailable space. Might still have room there to keep daily gear out of the way. The cockpit locker access seems inconvenient for getting sails in and out.]
    Press on! Curves ahead!
    Jan 2005
    middle earth
    What I Did On Starcrest
    For Sleep Accomodations I Put A Removable Drop Board Between The Existing Port And Starboard Bunks.that Allowed Me To Sleep Athwartships With My Head Up On Either Tack.the Same Thing Occurred In The Cockpit And This Arraingement Worked Out Fine.there Were Times That I Woke Up In The Middle Of Nowhere And Completely Forgot That I Had Left.
    Apr 2005
    Norman, Oklahoma
    Updates?
    Any new pics of your progress? I am just starting my interior renovation and was very inspired by your work so far.
