Results 1 to 15 of 619
    After several days of measuring and drawing pictures (and a visit to the chiropractor) I think I have a handle on how best to proceed with the forward 'cabin'. We'll just have to see if I overlooked some minor but critical detail that might throw up a roadblock.
    First off, the original bulkhead that separated the chainlocker from the v-berth had to come out. Last week, in some delusion fantasy I thought a new bulkhead could be glued in forward of the original such that I could use the original bulkhead to attach some 'struts' or some other means of holding the new piece in just the right place making installation that much easier.... What!?! You see, that's what winter does to the brain up here. Being there was a few other spots that needed the loving attention of an angle grinder and 24grit it was as good a time as any to extricate the vintage plywood. It was not as difficult as removing the ice box but not an easy task either. After cutting through as much tabbing as possible with the 4 1/2" grinder and the sawzall as far as I could reach the bulkhead was still firmly attached to the hull via a couple of nails driven into the stringers and some of that mysterious, funky blue bondo found throughout these boats. So I made a vertical cut with the sawzall through the plywood from the chainlocker opening down to the small drain opening on the bottom of the bulkhead figuring that I would be able to gain some leverage and 'wiggle' the pieces free. Much to my horror as I finished the cut the bulkhead pulled apart about 1/8" to 3/16"! I froze thinking the bow was going to split open. No creaks, no snaps, no light peaking in from outside.
    I crawled out and took a walk around the front of the trailer to see if I noticed any change or damage. Everything looked good. The single bow pad was still loose as I had left it a couple of weeks ago when we releveled her. So I concluded that it must have been some stress induced from sitting on her keel for so long. I try not to think about it much or start worrying. These hulls are tough! Not to worry.
    After cleaning up the dust and debris I remembered that I had always intended to continue the stringers up to the bow like Ebb had done. So out came the grinder again to clear the way for those. Then came the final sweep-up for the day and a good washing. Man, I sure wish I had removed the chainlocker bulkhead before I started retaping the hull/deck seam. It's tons easier working up front near the stem with all that stuff out of the way.
    Tony
    Never let it be said that you do anything half way.
    It is always so much easier to get rid of anything in the way and start from scratch when doing a project like you are doing. I can't wait to see what goes back in.
    samson posts/struts
    It's too late for lit'lgull to have her forward bulkhead repositioned.
    I'm convinced NOW that I want samson posts for mooring (and maybe have the bowsprit bear against.)
    It would have been real sweet to have a sturdy bulkhead right there inside where thru-deck samson-struts could be bolted to!
    Not possible to imagine how any bolt-to-the-deck bollard OR stainless samson post can be installed strong enough to hang a three ton boat from in a blow.
    I'll have to somehow connect the posts to the hull inside with braces and brackets or a molded in frp socket. Along with doublers under the deck, maybe have a cross beam in front of the posts.
    I'll be a problem in a now really restricted area!!!
    You are at square one, Tony, if you're planning a foredeck for anything but a marina tie-up!
    Interested to see what you come up with.
    I have about three days here where I can get some work done and then I'm away from the boat for a couple weeks. That'll be hard being she's prime for working on and I'm prime for workin'! I wanna see some progress.
    It's all pretty straight forward, as far as what's going back in. No frills and a mess less than I was going to try the first time around. Striving to stick with 'form follows function' philosophy. You know-KISS
    I am planning for on the hook and off the grid and into some diving again. As much as I loved SCUBA we'll be leaning toward free diving out of practicality. That's how I started anyhow! And I remember having a blast doing it too!
    I like the the idea of a sampson post, Ebb. But I am trying to reduce the number of things poking up through the deck. I suppose there is an easy way to keep them water tight and dry. And they sure would add to the stability of a sprit. I'm just looking to add a secure eye for a solent stay and a bit more room to stretch out if I have to take to the v-berth. Although, I really like the sprit(?)/anchor platform on them thar Nor'sea 27s. If we put a sprit on the nose I'm contemplating switching out the stem fitting for a simple strap like the backstay. What do ya think about that?
    Stem Strap. Yes many boats have that. Would save weight if you're going with anchor roller/channels.Remember you have to incorporate another attachment point for the foot of the sail.
    Another plate.
    Bingham, (the Sailor's Sketchbook pg80/81) has idea drawings of stem and double anchor roller weld ups which might be very useful for a small cruiser. Something like that would slip over the Ariel nose.
    And maybe even reuse the 8" bolt for the major attachment. That's the one that goes through the top hole in the original and exits through curve of the toerail/nose. Imco a VERY strong forestay attachment method.
    If your Solent is coming from a lower position on the mast but to the stemhead fitting, don't you already have a third hole in the fitting that can be used for that?
    Our current plan is to attach the solent as close to the top of the mast as I can get without interfering with the furler. (I know the furling vs. hank on argument-but I have a new furler and new head sail cut to it so I'm going to use it.) Then put a (what do you call it?) fitting about two feet back from the stem. A line drawn through these two points would intersect a point on the sheer a few inches above the waterline . That point is about as far as I can comfortably reach over the side of the bow. So I think that would be a good place to mount a sturdy 'U' bolt or eye that an anchor chain snubber could be attacted to. The backing hardware for this snubber attachment point could serve as an attachment for even more hardware that would secure the solent's hardware to the hull as well as the deck thereby taking some of the strain off of the deck whe the solent is being used. If we add a couple of inches of teak into the mix for an anchor platform/sprit that should strengthen everything up a little more yet.
    solent stay
    GOT IT!
    Actually got it backwards.
    If the reason for a solent stay is because you have a permanent furler on the forestay, then in theory the solent will be used for the storm sail - hanked on.
    That would mean you can put the attachment point for the solent as far forward as you need to and even get a decent sized staysail.
    The attachment for a storm sail in the Ariel deck is pretty technical, I think.
    If the solent is more forward then the 'U-bolt' can be backed up with a turnbuckle to a strongpoint built into the stem. I mean a turn buckle more forward would be less in the way in the chain locker.
    [At one point I imagined a reverse eye in the stem, attached thru the stem with the eye inside!
    Desperate measures - don't know if it is practical - but you do need imco more backup than what you can get with our composite deck and plywood.]
    A Solent stay is a movable stay.
    ABI is out of business and their Hyfield lever no longer available.
    Johnson makes a nice backstay turnbuckle with integrated levers for tensioning that have been used for Solent stays by others.
    Might be worth looking into. 5/16", $400!
