Looks top notch Tony... care to do it again on Faith?
I sure do like the traveler aft... especially for a cruising boat. Works well for going below, and the loose footed main seems to want end of boom sheeting IMHO.... but then there is a great big old thread on that IIRC...
Craig
I'd love to help with anything on Faith. I must have been dropped alot as a baby because I don't mind the itchy, I don't mind the cramped spaces checking something twenty times to see if it fits yet doesn't really bother me either. But, I really get annoyed when I epoxy my hair to the back of my head
End of boom sheeting really does seem like the logical answere precisly for the reasons you mention. Way, way back when Bill first shared his mainsheet set-up on 76 I ran out and bought one based on his unfettered praise. (going to copy his outhaul assembly too!)
My big hurdle now is wether to mount the traveler on the coaming, outside/behind the coaming or inside/forward of the coaming. On the coaming I would have to eliminate or reduce the amount of arc on top of the coaming that would mirror the lovely curve of our deck. Outside would be ok but then we have to add fairleads or tubes through the aft wrap of the coaming and move the traveler car control line camcleats to the inside of the coaming. Inside would be easiest for traveler operation and mainsheet set-up, however, I keep seeing some really tough angles and crevices to lay glass into.
For a while now each time I go up the ladder into the cockpit I look at that general area and no revelation yet. Anyone have an idea? A picture or two?
Found another candidate,(No, not one of those kind), and a Carl Alberg design to boot. What if the coaming wrapped around the lazarette hatch? Then the traveler could stay in the same spot, I could have my arc in the aft part of the coaming and maybe add one of those bimini tops that drop aftward! Ooo! 'just gave myself goosebumps!
I like the turning blocks. They would lend a kind lead to the winch if we're flying the MPG/Asym.
Flying biminis on sailing condos seem to be the rage these days.
Sept/Oct '08 Good Old Bateau has a guy talking about his 39 footer with a split-level transom.
"Two practical uses for two stays aft"
Split or double stays can mount the radar on a cross tube.
And also if you have a detatch tube frame bimini you can anchor it between the two wires aft.
An interesting variation having a 'mid-boom' gallows is explained. It also anchors the forward end of the bimini. And the author mentions we builder types start from unassailable points of view planning and building and then have to make important changes after gaining experience sailing it.
It's hard to figure where the mainsheet leads are.
His furled mainsail in the lead photo is one of those that incorporates a fully deployed sunbrella cover along the boom when the sail is up.
The dodger like the bimini is an all tube, rag and isinglass affair. It all looks like it can be taken down and stored below in case of a hurricane.
Hey Tony
Excellent work.
Sounds like you're planning a wraparound coaming. Would look nice, and provide more comfortable seating on top.
I cant see a good reason to have mid-boom sheeting if you have a boat where the boom reaches the end of the cockpit.
I would try to make the traveler as wide as possible. On many boats you only have about a foot of adjustment on either side--limiting the effectiveness of the traveler.
Here's what a few builders have done:
1st pic is a Schock Harbor 25
Next 2 pics are the Harbor 20
Then you have an Alerion Express 28 and 33
I hear what you're saying C-Pete. Used to "sail" on a C & C Mega 30 that had one of those 24" travelers right through the cockpit and of course at shin hieght. It was a bit of a challenge to move it to windward, or move it period, specially if the skipper thought he was Dennis Connor. Thinking back I'm amazed nobody lost a finger or more. Sometimes I wonder who was a bigger dolt, him for his actions or me for sticking it out.
I was hoping to use the full length of track which is four feet if memory serves me well. Of that length you lose 3-4 inches from both ends for car control blocks and cam cleats, but, that still leaves quite a bit of travel for a 26 foot boat with a 11(plus) foot boom. Between the halyard, cunningham, boom vang, out haul and traveler...oh yeah, mainsheet there should be enough sail shape control to pass the time getting from point A to point Z.
I did some rough drawing on one of the profile diagrams found in the Assoc. manual and a coaming that stretches all the way back and around the lazzarette hatch doesn't look bad at all to my eye. The lines coming off of the forward cabin 'shoot' back to a point just above the stern. This 3-day weekend will hopefully afford me enough time to pattern a full scale mock up of the perimeter dimensions. Then we can really see the difference between paper and plastic.
Have a good Labor Day all.
