Until the mahogany rails and rub-rails go on the boat there is a need to store the 14'-6" lengths somewhere, somehow. So I decided to make an extra long miter saw table with storage below it. The fences are removable, and, the whole thing separates into two 24" x 72" tables and the 24" spanner that the saw is mounted to. It seemed like a good spot for a router insert as well being most pieces I shape are either lengthy or else small enough to fit on a 24" wide table. There is a separate fence for the router.
