Thanks for the compliments, captains. I'll be the first to admit I stole every idea incorporated into Dream Weaver this far and 'we aint done yet!'
Still desperately searching for the best possible work surface/table arrangment. I thought we had found it in Frank's Revival but after changing 113's galley around it won't work there. The nav table refer location is mainly an inn table for the library. not really a ergonomically desirable work station. I'm back to eyeing the main bulkhead again. I seem to remember someone, somewhere storing a table on the overhead in their v-berth. That may be a viable option and if anyone out there has a link to that boat site.......
The sink is going back in pretty much the same spot it came out of just a little higher and a little closer to the centerline and a little farther forward. I think we'll valve the drain though before it ties into the cockpit scupper drain and seacock assembly just for good measure. Hopefully that will still leave enough room for the gimballed kerosene cooker and some outboard storage under the side decks.
Any thoughts, comments or concerns are welcome. Oh yeah, real world advice is greatly appreciated!
