Results 1 to 15 of 619
    Exclamation
    Go for it, Tony, nice work.
    Be interested to see what that upper step becomes. Guess you're partially closing off the V-berth 'aisle' for stowage?
    What is it they say?
    "A remodel of a thousand angles begins with a single piece of ply."
    Gorgeous prep on the hull!!!
    Tony -
    Do you take photo requests? I'd like to see what shape you settled on for the opening through the bulkhead... I really liked the rounded-corners one that you had prototyped in cardboard back many pages ago.
    Also, I'm thinking that I am going to sell my window frames, and go with Lexan bolted on from the outside. Probably too late for you to be interested in them, but I thought I'd mention it in case your molding hasn't progressed too far, or if you run into troubles with it (which I hope you don't! I considered doing something similar a while back...).
    She's looking reeeaaalll nice.
    I'll take a picture of anything!!! We're currently leaning towards the same shape on the top of the passageway and a flat foothold on the bottom. After stumbling through there so many times working in the v-berth I think a moving target may be even harder for me. Man, old age s****s!
    As of tonight we're ready to laminate the 'furniture' pieces that are going beck into the v-berth area. Then I'll have a suitable platform to work from for the 'toe-rail' job. yeeeh...
    Everybody seems to be dealing with the heat, so I'll spare you the whinning. but 90+ degrees and 70%+ humidity make hand sanding and shaping a little more messy. I've just finished off my first seven gallons of epoxy and I think I've sanded away at least four gallons worth
    found some time the other morning to cut holes for the dorade vents. The cabin top here was a full 3/4" thick. Cool.
    Because of the lack of room and, more importantly, the fact that I only had a 52" stick of teak left, we made a modified dorade box. It will still drain through weap holes but the air will have to go around a baffle. Such is life. I'll deal with it...
    What really stinks is my boring bit/countersink and plug cutter are two different sizes. I had enough scrap to cut ten plugs. Plan D
    Arrow Slick Dorade Innovation
    You know Tony, you may have something there! Never seen this design be for - and why won't it work? Unique!
    Everyday dorade boxes have one or two baffles across the box to help separate water from the air coming in the cowl. I can't see why Tony's horizontal/slant innovation won't work just as well - if not better!
    One of the 'improvements' I've noted in my collection of Other People ideas is the install of two access plates on top of the box. The idea being that in good weather you could move the cowl right over the hole to get direct air flow below.
    Another was to put on a lexan top instead of teak to get light thru the opening. Which is to say that maybe your slanted baffle plate could be lexan, or even the top as well? (The second plate over the forward opening might also get more air below with the cowl there!)
    Anyway, just my way of expressing enthusiasm for your invention! Way cool!!!
    Don't ferget the limbers in the corners!!!
    It's already August 12th. That puts me about...uh...mmm....4 or 5 weeks behind schedule. Just spent two week NOT working on the boat tending to other business. I was intending these last two week to be used for letting the paint fully cure. Ha!
    I was finally able to get back at this weekend. The v-berth fixins are tabbed in. Biaxial (4"), matting, roving, matting, cloth. That should be pretty similar to the schedule that what was in there to begin with. Anyone find anything different than that?
    The port openings have been drilled, threaded, redrilled, and the stainless bolts installed. The bolt holes got some epoxy pushed in, and now have two coats of fairing compound. Several more to go for sure!
    Made a White Oak beam that will get glassed into the lazarette (just for you, Whaleshark!) to become the backing plate for the backstay chainplate. If I can get a picture of what's in there now I'll post it. You wouldn't believe it!
    It's time to start looking at the hull too. I guess it's a bad time to be opening another store on top of all this. I mean, priorities being as they are, come on, the boat come first.
