We finally ditched the makeshift ladder I've been climbing up and down for the last howmany years... But I knew we'd have to shave the threshold down a couple of inches to keep that first or last step from being too much of a stretch.
Er....
Tony, doesn't this picture right above us here (264)
show a bump-up sea hood almost like 338s? It's a hatch garage - correct?
Mine is also pretty tall and that aesthetic Nag became agitated. But I prevailed!
"Form follows function, you fool..." Stuff like that.
Which may be the reason you're cannibalizing yours?
Takes courage to do something over again. Because we were SO sure the first time....
What I've been mulling over though is to use the height of my hood, there is a good argument to convert the forward volume where the hatch doesn't go into a dorade - two 3" cowls positioned near the sides and a single 4"D opening below in the middle. Would guess drainage would be quite efficient with the opening vent on the very top of the coach roof crown.
Buried somewhere in my notes:
Positive it was a well established designer that came up with the formula and drawings for a dorade that DRAWS IN air - it had to do with cowl size, interior volume, where the baffles are and how restrictive, and the opening to the inside. Some dorades work too passively.
Access plates and the cowl are big expenses these days. One idea I like is to install access/mounting ring directly over the hole inside - so that the cowl can be moved there for straight through air.
Watch that jig-saw! Beautiful works there Tony ----- keep her going!!
Somewhere in the piles and piles of boat photos we have an older, beauitful, European built woodie that has a dorade box just like what you're talking about... I think it might have come from the Abeking & Rasmussen site. Anyway, I bought cowls with way too high of a profile. That RBV would act like a bat and send me slack-jawed into the briney to recover the shiney.
Lower profiled cowls would probably work right there and the inclusion of vent protectors might even work as a good attachment point for lines or organizers.
Instead of adding new posts to the thread I've just been using the edit feature to add new pics. Epoxied the new outer skin onto the dorade boxes this morning. Hopefully we will finish the inside layers tomorrow.
Well, too much job and not enough 'work' getting done. If you know what I mean The nice thing...on Sunday the temp was in the 80's and the humidity was in the 70's. Love that mix. Seriously.
Got a couple of hours of work done today. Uh-boat work that is, and only after meeting my obligations at the job that pays the bills.
Started laying the foundation for the garage. This includes pitched 'drains' that empty into the cockpit. Placement of sacrificial mmm, 'stuff' for the hood scuppers and shaping the wadda ya callit backwall...
Next we'll make a foam nose cone and add some sexy-smooth taper to the sides of the rails. Then out comes the grinder again. Yee-Haw!! After puttin a groove on the roof top we'll glue everything in place.
We ground a groove around the structure that has a 1/8" to 3/16" deep dish about 1 1/8" wide to accept the bulk of the tabbing. Outside of that groove there is a 1/16" deep by 1 1/8" wide area to take the top layer of cloth and fairing compound. These measurements, while not exact, are depths into the actual FRP not the paint or gel coat.
This was taken the next moring... we spent the day drying out all our cushions and bedding... everything onboard was so soaked it was like someone had turned on a fire hose below. All of the water had come in one place... the small gap under front of the sliding hatch.
