Tony, despair not!
www.caswellplating.com
I fixed the deadlight frames with a one part aluminum putty/paint from these guys.
The frames went thru the powdercoat baking process no problema.
There are a number of metal fillers with video names. Get the aluminum filled one they use on mufflers or is it engine blocks. Hey. WHAT kind of epoxy is THAT?
[Hit the 'Repair' bar then look for Lab Metal. I used the lower priced stuff without problem. Don't have any tips really on using it. Painted it on, it is a loose paste, one part, let it set up. Filed like metal. Get the solvent too. It might not even be epoxy....YEA!
There are two part putty sticks like Aluminox and Permatex makes putties too, never used them. Even West System, has aluminum powder to mix yer own. But the high temp stuff is more intriguing. And I vouch for Lab Metal. It goes on wet. I felt I got something that LIKED aluminum, looks like aluminum, and became aluminum.] LYCKA TILL
