hull speed, schmull speed...
12-15kts blowing and we defied her theoretical hull speed. (know it's been done before by all of you, but not yet by me)
Our return to port is dictated by nap time, so after a couple of hours, we were done. That's what all old salty captains over the ages have done, no? Children's dramamine kept my daughter from barfing this time at least. That is a nice improvement on the sailing experience for all.
Inclinometer doesn't work, but she heels nonetheless. (Ritchie said that it would be about $50 bucks and a couple weeks to put the gimball back on its pivot point.)
Anyone know what (if any) is her optimum heel for greatest hull speed? I know that 0* is the optimum heel in my lovely wife's opinion.
Kyle
I haven't spent a lot of time measuring the optimal angle of heel for the Ariel but A-231 is pretty happy at 15-20 degrees...
I have a similar compass (mine's a danforth saturn). I've not seen this failure mode with my current model, but you might be able to shake the lubber lines back on the pivot if you take it out of the bulkhead... It worked for me with a previous compass.
Good luck,
Bill
p.s. ritchie has the service manual on-line for your compass if you feel like taking it apart!
http://www.ritchienavigation.com/doc.../Navigator.pdf
Reason: added link to service manual
Thanks Bill. Will give shaking the compass a little a whirl before I send it to be serviced.
I was wondering on the heel because I know (though I can't remember what it was) that my MC Scow and my old Laser had optimal angles to get the right wetted surface in the water, and too much heel was counterproductive for speed. Yesterday we were heeling like crazy at 6.1 kts. Tonight on our pizza and cocktail cruise in about 7-10kts of wind we were doing 5.5 with almost none... Just learning the moods of this beautiful boat. A nice pursuit, I'd say.
Agree with Bill--15-20 degrees gives you a longer waterline
If shaking the compass doesn't work, you can buy a seperate inclinometer. A cheap plastic one or something more fancy
http://www.brasscompass.com/inclinometer.htm
beer bottle in a cup holder?
That oughta do just fine, Ebb.
Splashed around on Lake Michigan today for several hours. 10-15kts 2-3' seas. Fun ride. Tried out my new jib downhaul - worked like a charm and a great day to stay off the bouncy foredeck if not necessary. A couple pix below.
Despite the corkscrew motion of the boat, note my obviously stressed out crew.
Reason: dead link!
Well, as long as I'm not in danger of being the most voluminous picture poster... A couple more pictures below.
I installed my cowl vent and its canvas cover. A nice visual addition, though it doesn't seem to supply a great deal of air flow below. May be helpful for venting interior heat whilst the boat is closed up.
Had an interesting non-critical, but closer than I'd like right of way issue with the 192', 148 ton Lake Express car ferry today. http://www.lake-express.com/about/vessel.aspx I was sailing SSE at about 3 knots passing 1/4 mile east of the Muskegon Lake Channel. I had heard the Securite' announcement of the ferry arriving and was well clear of it's course as it came down the channel. However, the ferry hit the end of the channel (runs WSW to ENE) headed inbound to its dock approx 2 miles SE and she swung 30* or so to starboard and therefore headed far too close to my course for my comfort. I altered my course 45* to port and sailed well out of the way. Being on the short end of experience, I presumed I must have been in error, but called the Coast Guard station by cell phone after the fact to get their read. Not complaining, just wanted to get an opinion on the situation. Per the helpful Coastie, "It sounds like you had the right of way, but in the end, gross tonnage wins." He said it may have been a draft issue, but that area of the lake is 35-50' deep for a wide area and the ferry draws only 8 feet. May have been more of a shortest distance between two points issue. Coastie said he was following green bouys, but none are visible on the lake. I know right of way wise, he's likely considered comprimised in terms of his latitude to alter course, but on his pre-freak-KW-out course, I was well clear. I was one of only 2 sailboats out today, so I presume it wasn't a visibility issue. I was, in fact, sailing on a close stbd reach and by going around me to starboard, I had a wider latitude to sail away. Had he gone to port, I could have been pinched had the wind shifted or died. Again, I contacted the USCG just to sure up my nav skills and so as not to make the papers at some time in the future. I think it would have been helpful had he announced his intention to alter course prior to doing so at the end of the channel. Should I have hailed him to get that info, or is it his responsibility to be clear in his intentions? In the future, I will be well, well, WELL clear....
