Results 1 to 15 of 334
    Scott, to the best of my knowledge, that is a new oak tiller and newly fabricated tiller head. I took a picture of the head - Sealand model 960. Same as Mike's. See below.
    One seacock onboard below the sink. Port and starboard cockpit drains are identical clamped (painted) rubber hoses - see below.
    There is an unidentified (by me) drain in the bilge which I assume would accomodate a bilge pump. No pump - except a manual one - onboard so far. That seems like a must-do.
    I want to bring a bucket to the yard next visit and with a spotter below, pour some water through the two scuppers and two cockpit drains.
    Can anyone identify the fitting in the last two pictures? It is on Stbd a couple feet from the bow. Interior fitting leads to the chromed exterior fitting (sorry it is blurry)
    Aug 2006
    Tulsa, Oklahoma
    fittings
    I believe the unidentified fittings are one fitting and it is a water tank vent. Most water tanks vent inside but some people vent them through the hull. That's as far as my mind goes on it.
    the genoa track through the toe rail is simply bolted through. No backing plates. Wonder if this is a problem. If it hasn't failed or leaked in 43 years....
    Fore and aft terminations of the coaming-top rub rail. They end about 2 feet from the aft end of the coaming.
    the panel in front of the head.
    and (with all due respect, coming after the head-panel picture) my superb crew.
    Still waiting on the yard's crane to help step my mast... "Oughta be today" - have heard that several times now.
    Lucky Dawg came with a load of sails! I have some experimenting to do. A main with one reef point, a "storm main" (that doesn't seem much smaller, but is beefy as all get-out.) A working jib, a storm jib, 4 genoas of various (but quite similar) sizes, and 2 spinnakers. The surveyor rated them as a group as "painter's tarps" which might be a little bit of an exaggeration, but that may remain to be seen.
    All of my sails are boldly marked with "6091." Not sure what that particular number is in reference to, but every sail has it blazin' across. I'm thinking that white paint over those numbers and "65" placed there instead probably would look tacky...
    My newbie-ness abounds, but I must admit that I don't know how to fly my spinnaker yet. I mean, I understand it in theory, but having never attempted, well... KW has lots o' learnin' to do.
    Often, a number such as that is an "off shore" racing registration number. Yours is pretty early as the more recent ones are up to six digits, maybe more.
    Thar she blows!!
    Applied my new boat lettering today. Just used a buffer and rubbing compound to take the old name off (With all due respect, "Someday" was a little wistful for my tastes)
    Will attend to the rituals of renaming* upon launch tomorrow at 3PM!! WAAAAAHHHHHHOOOOOOO!!!
    (* Some personalized combination of http://www.boatsafe.com/nauticalknowhow/rename.htm and http://www.48north.com/mr_offline/denaming.htm)
    Your unidentified bilge fitting in post #25 looks like a thru hull for a old datamarine speed sensor. If it unthreads from the inside to expose a cylindrical plug sealed by o-rings, there's a good chance that's what it was....(better to check before you launch rather than after)
    good luck on the launch hope all goes well.
    Thanks Bill. There is, in fact, a sensor on the outside of the hull in close proximity to this bilge fitting - I hadn't connected the two in my brain. It appears sealed up and the PO didn't ever have a speed sensor running. It had several coats of VC17 covering the window/transducer. I checked the DMI website and making it again operational looks pretty pricey. http://www.dmimarine.com/parts/index.html. My GPS will do the speed sensing for now.
    On another speed note, my 8hp Yamaha cranked on the second pull. Whew.
    I've been very pleased with Torresen's Marine. As you might imagine from my posts, I have LOTS of questions. They have been super friendly and happy to take a gander at anything I have asked. I am a sucker for good customer service and they've been a pleasure.
    First family sail on Friday. Have a lasso, er, teather... and life jacket for my daughter. Getting a 3 year old to wear it without squallerin' is the challenge. (Not getting her to so much as listening to the protestations should she begrudge it!)
