I coated the disk with a thin layer of thickened epoxy, then faired as well as I could. With it being on a vertical surface fairing was a little difficult. I imagine there will be a small amount of light sanding with my random orbital tomorrow once the epoxy has cured. This will create that nice surface flush with the backside of the keel that the future laminate gets adhered too. Plus the area is now sealed off which feels good. Hull for A-24 is regaining its integrity!
