Layup cont.
In total I applied 16 layers of fiberglass. The reason for the high number of layers is that I decided to use the 3oz. cloth I had on hand. Perhaps not the best choice of cloth and it was time consuming, but the repair integrity will be good. In fact, I am willing to bet that part of the hull is the strongest part of the hull. The area is pretty fair, but once the last few layers kick I'll smear on a thin thickened epoxy coat. This will be allowed to cure overnight, then I'll remove the amine blush, sand, fair with one last thin coat of epoxy, sand smooth, paint, then I'll be done!
16 layers of fiberglass reinforced epoxy.
