Results 1 to 15 of 150
Thread: Commander #155 'Mephisto Cat'
    Mar 2006
    San Francisco - or Abroad
    Yeah... They are on. I left them off until I stepped the mast. See picture below.
    Here is a pic during the first 'test' sail a few weeks ago!
    I've already completed the first leg of the passage. (Picts on that soon... )
    C-155 is currently at Newport Beach Harbor in Orange County. We head up to Marina del Rey tomorrow.
    Backstay Chainplate From post #28
    I had no more room above so I posted the template for the backstay chainplate attachments here. If you print at 1:1 scale you will have it in full scale.
    RE: Pic no. 2 above - it's interesting how even Commanders with their small cabins look sort of "top heavy" in the profile view without the coamings. Nice coamings make such a difference on these boats.
    I don't suppose you'd mind posting a full blown glamor layout of Mephisto all rigged and assembled? She must look absolutely gorgeous!
    Did you paint the topsides as well?
    Mar 2006
    MBD - It is all new Gel-coat all around... Outside, inside, underneath, etc... I got some bits that the Pearson factory even missed...
    I even Gel-Coated the lead pigs! - A bit carried away - I know... but is is so much nicer to handle these blocks of lead when they are covered in nice gel-coat.
    As I mentioned above - the trick in these matters is to know when to stop painting (coating, in this case!)... I only stopped when there was nothing more to coat!
    Pic: This is the very first outing with sails... (a couple of hours before the next picture below was taken), We were just going back & forth in the marina... just to see if something important had been left off (or fell off) before going out on the open ocean!
