All right!
I took your advice and bought one smaller Ryobi set, and my first impression is good - they seem handy and sturdy and designed with a lot of attention to detail. I got the $129 set at Home Depot that includes the 4 tools: drill, circular saw, detail sander and light. It comes with the charger, 2 batteries and bag. Now my fingers really start to itch!
Thanks for the advice about the sanding. Sure I get an orbital sander. Two dozen discs??? Sounds like I'll be sanding the whole day long! I've never done this at all and so have no idea how long ittakes. How can you tell if you sanded a spot enough? I would guess when it doesn't shine anymore?
I won't likely do this this weekend since the boat is outside and it's expected to rain a lot. But I'll attempt the repair on the deep dings and gouges I showed you guys in my other post. I read up on your posts about the use of poly vs. epoxy and am a little surprised that it's not a clear thing - well, not really. I start realizing that there are many ways to do the same in boating, and that's part of the fun. As somebody said in another post - if it doesn't work out, just grind it/sand it away and try again!
