Page 19 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
Results 271 to 278 of 278
Thread: Ariel #97
  1. #271
    Apr 2015
    Chicago, IL
    Very Cool. Why don't you make it an articulating prod? You can pivot on the headstay post.
    carbon fiber sprits
    Seem to be out of the loop here. But I've been looking at the Trogear A-sprit. Two tubes
    ideally coming from the bow slightly below the toe rail frpm either side of the bow. Can
    be mounted on top. The A frame legs have only 15 degrees of separation, making it quite
    narrow. Have not trialed with mockups but believe it won't go much further inboard than
    12/14", where it will have a fiberglass tube and a long 1/2" bolt from side to side so that
    the sprit canbe raised and bungeed to the stay. Has a 1/2 bolt thru holding the Sprit
    weighs 5lbs.
    The bobstay is shown in the literature is a modern guntackle - led aft to the cockpit! In
    preliminary emails with Trogear, it is possible even to have a 'simple' rod bobstay, no
    turnbuckle and chain. Don't know yet how actually it's rigged. But like the simplicity.
    My mast has what I think is a true Solent tang about 18" below the masthead fitting.
    That stay will go to the stem fitting. Think it possible to rig this stay permanently,not
    readily removable. And have reefer/furlers on both stays, or a hanked on staysl and self
    contained asymetricals or screechers with their own attached furlers...?
    Also, the top long bronze bolt of the original stem fitting that goes thru the fitting to pop
    out conveniently on deck is the strongest method I've ever seen. I had mine recast with a
    fatter five-hole fin to take pin and stay loads better. Original toggle holes were elongated.
    Those Trogear A-sprits are extravagant. Already have a self designed aluminum sprit that
    I really like. But it's too heavy for the bow, too much for the boat. Shave 20lbs first off
    on bowsprit alone. 5lbs, or more, on lighter bobstay gear. Anchor gear on deck will be
    easier and maybe lighter with the bowsprit free and not part of foredeck clutter.
    If I keep the hinge-up option for the A-sprit, the sprit can be folded up to pulpit making
    sail attachment and retrieving easy. Something recent events make quite necessary.
    "Easy does it, and if you can't go easy, go as easy as you can." Gertrude Stein
    Couple coats Aluthane will make that $$$$$ snooty black carbon tube look like a good ole
    aluminum spar!! Imco.
    CARBONSOUP________________________________________ __________________________________
    From the future: 10/19/21
    The Trogear wishbone bowsprit is indeed an expensive and gorgeous piece of work. And
    I did coat it with that amazing Aluthane, to me still great inventions. Hasse cruising sails
    still need a bowsprit but also a place for an anchor-roller. Trogear allows no space for a
    cruising anchor system - it had to go.
    It's taken me literally FOREVER to get Litlgull ready to leave the Bay. I've stopped work
    an embarrasing number of times. I've gotten older as well.
    But discovered the dream is in my blood. There's nothing else but declining in a rocking
    chair. End as a nasty curmudgeon with alzheimers or parkingsons or canser. 1/2 way there.
    Urge Skipper Soup, below in these posts, to immediately launch A97 ang go sailing. Spruce
    the ship up a bit - that would attract a partner.
    Our Ariels and Commanders are foremost a form of ENERGY, Carbon you can't quit now!!!!!
  3. #273
    Sep 2012
    Philly, PA
    wow, that is a nifty bowsprit, though I dont see what the pivot is about. The Trogear is a pretty nice bit of kit as well. However, I am making a permanent bowsprit for the forestay. Currently, I have decided to set the distance at 18" from the bow, nothing extreme. As I said, I am trying to balance the rig a bit without having to shorten the sail area... some of you all are probably rolling your eyes. Nonetheless, I work at a metal fab shop and so far this little experiment has cost me nothing.
    as a side note.. I am taking on more side work (design & fabrication) as I begin transitioning myself towards opening my own shop, so if any of you guys have some fab work let me know. For example, one thing I was thinking of making extra are some SS trim rings for the aluminum opening ports. The cast aluminum trim rings that I have are in many pieces. I am going to laser cut 12ga SS ovals... when I get a chance
    A97 build images, drawings and other data:
    https://drive.google.com/drive/folde...vh?usp=sharing
  4. #274
    Talk about nifty. Laser cut, I don't know the machine. Is it like a CNC that you program with
    a computer / Shop here has one of those (personally don't know how to program any
    computer) but it cuts with regular milling bits. What I'm asking: can you program individual
    jobs? I had my aluminum opening ports powder coated. Because the coating is relatively
    thick the trim ring now no longer slips over the spigot. Everything could remain the same
    spec but the inside oval has to be slightly bigger, maybe a 1/32" all round. Would you
    provide the fastener holes also?
    The Troger A-Sprit can be mounted on deck, or as it happens, on the molded toerails, at
    that height. That means one can micro adjust how much the bowsprit will project out.
    They have end fittings. The preferred way is to mount the A-frame outside of the toerails.
    Because the A-Sprit 15degree angle is not adjustable, that means because it is narrow it
    is fastened pretty much forward on the bow. And down enough so the a fiberglass tube is
    glassed in thru the bow (when you look into the forepeak you'll see it). A long bolt, possibly
    threaded rod holds and hinges the spirit on, so it pivots. Or you can permanently mount it.
    I had some preliminary email discussion with one of the A-Sprit designsers about permanently
    mouinting the sprit. My thought is that carbon tubes are not really good in compression.
    So I understand. But did get qan OK to use their thicker wall tube model... at a thicker
    price. But then it occurred to me to axe the Solent idea, and use the inner forestay to rig
    that mast at higher tensions.. And use the jibstay with light weather larger sails with the
    sheet winches. Like the idea of folding the sprit up to the pulpit and attaching or removing
    sails. And paying less for footage rent in marinas.
    Best of luck with your new business!!!
  5. #275
    You start making S.S. port lites I might be interested in a set.
  6. #276
    Sep 2012
    Philly, PA
    ugh. its been a while since i have worked on the boat, even though I see it everyday sitting in my shop. Even more annoying is Photobucket forcing me to pay for 3rd party hosting of all the build images.... so lame. I was emailed by a gentleman who wanted to see some of the images of the build, I had not put 2+2 together to figure out why he was not able to view the images on the forum.
    anyone have a silver bullet? if someone can give me a good solution I swear I will do some work on the boat!
  7. #277
    Sep 2012
    Philly, PA
    Man, it has been forever! thank god Photobucket hasnt completely deleted my photos....
    However, because I wanted to share ALL of the photos, models, drawings and data of the rebuild of A97 I have uploaded them to to my google drive.
    Contents:
    1 - Spec Drawings
    cleaned up original "lines" drawings
    vector files of the "lines" drawings
    original/novel interior drawings
    3D models
    2 - Construction photos
    pretty self explanatory
    3 - Electric Conversion
    Useful calculator and electric info (as of 2014)
    Custom electric drive mount (drawings and model)
    4 - Logo Emblem
    Original Ariel emblem pattern in PDF (vector file editable with adobe illustrator)
    various logo images
    5 - Rigging
    v1 New mast head sheave box designed by Destiny (mike)
    v2 Newest mast head design with "over-under" sheave placement.
    Other various rigging info
    7 - Trailer
    Trailer design and info
    construction images
    8 - 1960s Brochure
    Original artwork and brochure of the pearson ariel
    9 - Previous Owners
    1st and 2nd owner images
  8. #278
    Sep 2012
    Philly, PA
    I guess it would be obvious, but I havent had the opportunity to work on the boat in a very long time. It has been sitting in storage for the last 2 years.... and I dont think I will be returning to finish the job unless I get some renewed motivation. If someone is interested to purchase or partner in completing the project please dont hesitate to contact me. The boat is ready to roll (anywhere in the country).
    best, matt
    https://drive.google.com/file/d/1j2V...ew?usp=sharing
    The retrofit, list, in no particular order:
    1. Interior completely deleted and replaced with a unique design suitable for two to cruise Maine to the Bahamas. all interior plywood Okume BS1088 marine grade plywood. Sleeping for 4 (1 bunk under cockpit, large double in main salon, 1 bunk in bow) 85% complete
    2. Retrofitted Four-Winns trailer motor boat trailer (2 axle w/disk brakes and pivoting tongue) 100% complete
    3. Custom electric drive mount w/ 8.5K electric motor (complete electric motor kit has been mounted and test fit, but never tested/run), 75%
    4. new PPY no drip drive shaft, 100%
    5. new cutlas bearing, 100%
    6. hull/deck seam fiberglassed, 100%
    7. deck recored (previous owner), 100%
    8. new stainless steel prop shaft, 100%
    9. 3 blade (12x) prop, 100%
    10. new main 4:1 sheet w/curved main sheet traveler, ready for mount
    11. curved jib sheet tracks, ready for mount
    12. rudder, completely new w/original bronze tiller shaft. needs final fiber and fairing. 90%
    13. mail sail, brand new (used a dozen times) Beacon Sails in Annapolis
    14. hull mounted chain plates (interior), 90%
    Extras:
    1. I started designing / fabricating a bowsprit (18”) from 316 Stainless steel to help with the weather helm.
    What she needs:
    1. rebuild cockpit coamings. I have 5/4 mahogany planks ready with pattern.
    2. complete wiring, including electric drive integration and batteries.
    3. needs all new lighting
    4. electric drive testing
    5. Remounting of all the original hardware
    7. The boat needs top side paint and deck painted.
    Basically, I would like to “finish” the boat by getting the boat ready to drop in the water. After that, it would be up to you to finish the interior and get the rest of the systems running.
    How much:
    1. I have no idea.
    2. I might be interested in partnerships….
