Results 1 to 5 of 5
Thread: Commanders Head
    May 2002
    Rochester MN
    Question Commanders Head
    Our commanders head has had it's through the hull intake removed. Are there on board supply tanks availible? What locations should be considered?
    Thank You
    Rockville MD./boat kept at Annapolis MD.
    Heads
    Since direct discharge heads are illegal(unless you have a Lectra/San) just about everywhere but 3 miles off shore I would go another route like a porti potti unless you have a holding tank.If you do just install another thru hull for the intake.
    May 2002
    Rochester MN
    Thank You,
    There is a black water blader, I was not sure I could use a frest water intake.
    Steve,
    Nov 2001
    Fresh water intake is fine, and fully legal. That is the way my boat is rigged, and the only way I know of doing it. West Marine has a small pamphlet on the legal ways to hook up a plumbing system.
    May 2002
    Rochester MN
    Theis,
    I will look for the info in West Marine.
    Thanks,
  1. Enlosed Head?
    By mbd in forum Technical
    Last Post: 05-25-2010, 07:51 AM
  2. Knotmeter Head Replacement Knot Fitting
    By Bill in forum Technical
    Last Post: 03-29-2006, 01:04 PM
  3. Orcas Island Sailing Commanders
    By Bill in forum Gallery
    Last Post: 08-23-2005, 11:35 AM
  4. Head installation & water tank conversion
    By SailorLiz in forum Gallery
    Last Post: 08-11-2005, 05:02 AM
  5. Head sails
    By French in forum Technical
    Last Post: 03-11-2002, 11:39 AM
