Page 4 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 46 to 60 of 249
Thread: A-50 Revival
  1. #46
    Double Bunks cont
    Frank also has a double bunk in the main saloon. Here are the filler boards in place. He's also recycling former V berth foam and cloth. (Note the shower sump glassed and painted with 3/4 pickup not yet screwed down.)
    Here's the mockup for the cushions in the main double berth. (Note the grate on the shower sole.)
    Forcabin Shower
    Here's the completed shower. The curtain is on a flexible track (from Boater's World).
    Here's the forward bulkhead in the main saloon before . . .
    Here's the same view after Frank has given it his special treatment. . . . (Note the curved board with holes from the varnishing rack.)
    May 2004
    Pembroke Ontario Canada
    Talking boring shower curtain
    Check Kent's curtains on 376. His daughter picked his out. I was alone on a working vacation doing this ...mine are 'boring' , so I promise to post pics of the 'new' curtains my girls pic out. . PS....Tony G...there it is...the shower..it's sump goes to an inside bilge pump. The pump has a y valve to the bilge also ,so either the shower sump or bilge can be pumped out from below.
  7. #52
    Table
    To add to the comfort of REVIVAL, Frank is installing a Ship's Captain's table. Wonder if it will have a green felt cover . . .
    Guess no green felt -- appears to be varnish. Looks like you can leave the table up and just close one leaf to have access to the main hatch ladder.
    Tanks
    One of REVIVAL's holders for the new tanks. New seacocks to come . . .
    Here's a 20 gallon tank installed. Port aft seacock is for raw water to sink.
    May 2004
    Talking hose for drain
    That hose at the front left of pic on the 'cup hook' is for draining the ice box
  12. #57
    Thumbs up Very nice
    That brightwork on the bulkhead really is nice, as is the other work you are doing. Looks great Frank,
    I have that 'queen size bed' option as well. I love it, and recommend the mod highly.
    I do like the idea of the cockpit bunk. Do the cushions from the main cabin fit it as well?
  13. #58
    May 2004
    Wink cushions
    no...I'm getting cockpit cushions made .The larger center filler will double as a forward std side bunk cushion.
  14. #59
    May 2004
    Wink cushions again
    The filler cushions in the main cabin will double as backrests and arm rests when not in place for the double.Makes real cozy reading corners both sides
  15. #60
    Frank,
    GORGEOUS! Absolutely first class. Genius.
    I'm having trouble finding a place for the hot-tub, should have run it by you!
    Could you please give us a photo demo of your settee to double bunk setup?
    Oh, and what brand is that white stuff you have everywhere? Nize.
