Kurt...I put 1" foil sided foam under and on 3 sides of the cooler...blew 2cans of foam around the rest.Hooked a hose up for a drain..comes out inside the companionway...sets up on a cup hook.When ya want to chill a white wine , simply drain off a lil cold water into a jug holding the bottle !! (stole that from the Pardeys too...can see in a pic #50 way back) oh ya...the cleat..NO CLUE..po..but it makes a good handle for removing the step !
