Page 6 of 21 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 LastLast
Results 76 to 90 of 307
Thread: Ariel #414
  1. #76
    Quote Originally Posted by mbd
    Oh 3rdman... Will I post this before our omnipresent moderator Bill does? "If you use the 'search' button at the top of the page"...
    Thanks!
  2. #77
    A busy weekend - grinding. Lots of it.
    BTW, when I cut along the coach roof and toe rail, I cut as close to the edges as my circular saw guard would allow. Don't do that. Add maybe a half or an inch or so to that. The thin strip along the edges is difficult to get at with a sander, and impossible to grind at the right angle for a scarf joint. You can still dig the material underneath the edges out and stuff thickened epoxy into the crevices...
    Sea Glass (Ariel 414)
  3. #78
    And my first ever fiberglass job - phase one.
    First, I slathered as much unthickened epoxy into the cracks as I could and wetted out the bare glass. Then I thickened what was left to fill the big gaps. Next I cut some of my 8.7 oz 4" fiberglass tape into 2" strips which I laid on the seams then wet out with unthickened epoxy.
    I tried to roll out bubbles and squeegy off the excess before the epoxy gelled and became unworkable - with mediocre results. I got a can of slow hardener last weekend after I almost detonated my first big batch of epoxy, which gave me more time to work, but still, I attempted to do too big of an area at one time...
    I would have liked to finish off with 4" strips and cloth to complete the scarf joints, but I ran out of daylight and weekend. Too bad, because the whole chemical vs. mechanical bond deal, but what can you do? Plan better, I guess.
    I sure wish I had one of the experts looking over my shoulder! The job leaves much to be desired I'm sure, but at least the deck is getting put together instead of taken apart for a change. Besides, I can always grind it back down and try again, right?
  4. #79
    Jul 2004
    Winyah Bay, SC
    Mike -
    I've been meaning to post that it sure looks like any 'expert looking' was done from *between* your shoulders, not over them. Nice work, she's looking good!!!
    Kurt - Ariel #422 Katie Marie
    sailFar.net
  5. #80
    Thanks Kurt - I'm currently waiting for the deckwork from last weekend to cure. Almost 4 days and the whole side deck is still tacky!
    I had switched to the slow hardener (West System 206) to give myself more time to work with the epoxy, but the high temps in Maine since Saturday have been barely above 60 and drizzly. I've got four pots that I used for mixing various batches, and none have hardened - and I don't think even I could screw up mixing four different batches! I'm really hoping a nice sunny warm day will harden it up.
  6. #81
    Angry Ho boy!
    Ummmm... I've been wrong before, too.
    So, I'm using West System epoxy (availability, reputation, documentation, marketing , etc.) They have this handy "pump system" where the 5:1 ratio of resin and hardener is measured for you - all you have to do is count the number of pumps of resin and hardener. Not so bad. Worked great the first time I tried it. About as idiot-proof as they could make it really.
    Well, after finding the epoxy still tacky last night, four days after finishing the job, I began combing through old emails and rereading the West System User guide, trying to figure out what the heck was going on. Then it hit me. 5:1 ratio. 5:1 ratio. Wait a minute! The pumps... The @#!$# pumps! I had actually done it. I had outsmarted the idiot-proof "pump system".
    I don't know, I guess I was really preoccupied with other things, like: Am I doing the scarf joints properly? Should I be using the 17oz biax, or the 8 oz cloth now? Have I washed and ground down the previous layer enough? Can I get this done before dark?
    And I kept thinking 5:1 ratio, 5:1 ratio. Don't screw it up. So that's what I did: 5 pumps of resin, 1 pump of hardener. Over and over and over again. I did indeed mismeasure every single batch of epoxy I mixed last weekend. ALL of them. The entire day's worth of epoxy and glass and filler on the starboard side deck. What I did in reality, was mix a whole bunch of 25:1 resin goo.
    Needless to say, I'll be learning how to remove and clean up uncured epoxy this weekend...
  7. #82
    Mar 2006
    Havre de Grace, MD
    geesh, Before you go stripping off all that mess, I'd call West Sys, and see if theres and easier way even baking it would be easier then scraping all that crud. I wonder if some time at 140 deg, or so, would cure it.
    #97 "Absum!"
  8. #83
    yea, I'd call them too!
    It is not unlikely that misbatched epoxy will go off eventually, just a matter of time. Don't do anything radical yet! Might depend on how far off your part A to your part B was.... Call the product tech! Maybe the set can be speeded up with a heat gun.
    Project looks first class!
    Instead of the pumps you might try the graduated translucent plastic quart containers that most alternative suppliers have. I get mine from TAP. Ounces and milleliters printed on the straight sided container makes it simple to get the proportions visually.
    You go for the amount of epoxy you think you need (in your case) marking off with a sharpie 5 measures plus one measure - whether they're 2 oz each, 1 oz each, 1/2 oz or milliliter multiples. It's no brainer, I make myself mark off the proportions every time I mix a batch: 5 equal spaces to one equal space, whatever the quantity.
    (I'm a two to one fan, but the point is you look at, actually thru, the container as you pour Part A up to the 5 part mark -where I've made a longer line with the marker - and then top off with the hardner. This would work especially well if you are using epopxies with differing proportions.
    The marker lines wipe off with denatured alcohol, my cleanup solvent of choice. I'll often clean out the container with paper towel/rags and use it again. Depends on the timing. I keep similar 1/2 gal buckets to mix powders into a batch: silica, fairing compound.
    I have trouble trusting the pumps. If you keep them in the cans over a period of time, Part A will gum up and the squirts will not be true measure. Also if you have the cans around for awhile you want to screw the cap on. What do you do with the pumps? Toss em? Unless you want to go thru the mess of cleaning them and wasting solvent.)
  9. #84
    I tried the heat gun earlier in the week. It thins the mixture when there's not enough hardener to "kick" - which incidentally is the way West suggests removing it. I also tried the heat gun on one of my used mixing pots to see what would happen. It just made it runny.
    Ebb, I've got lots of the clear buckets with marked measurements. That's how I started out, but pouring the resin and hardener from the jug and cans was a messy and wasteful affair, and I invested in the pumps.
    I also called West with a "hail mary" and took little comfort when he said, "You're not the first to do it." In light of the fact that I used the slow hardener, the temps are hovering around 60 and it hasn't started to cure yet, he said I'd be better off removing the questionable stuff, which I'm inclined to do anyway because we're talking about the structural integrity of my deck.
    Ironic. In the software biz, I strive to write "idiot-proof" code 40 hours a week and I've concluded many times over - you just can't save some people from themselves...
  10. #85
    Hey Mike, Guess you have to make up a proportion code sheet.
    Like 72 squirts part A / 14.4 squirts part B = 8 oz
    100 squirts pt A / 20 squirts pt B = 12 oz
    ETC
    Had to find a supplier for empty F-style gallon cans to screw in the pumps. Befor I nixed the pumps. But I got to like the wider mouth cans - you can look down the hole to see what's doin in there.
    I buy Part A in 5 gal bombs weighing 600#, it seems -so I have to decant with a funnel into smaller containers. No fun when the big one is full. I got a big mit and find it pretty easy to pick up a rectangular can by its side and tip it into the quart container - laboratory style at eye level one in each hand. Not you? You only need to have it half full, weight wise. Anyway you probably aren't set up for continuous use like 338 is.
    Spent an inordinate amount of time last few years with a gallon can in one hand and a quart container in the other. The wider mouth means that the syrupy epoxy pours out rather than BLOB - which indeed can get messy.
    Earlier threads point out that 2 to 1 and 1 to 1 epoxies are better to use. And easier to measure. One reason is that they are more tolerant of mistakes because they are essentially the same stuff in each container but one has the hardner. Been said these epoxies are in a premix state already on their way to set. Sometimes indicated by zero induction time. This might have been true yesterday, but today there are 100s of new epoxies!
    You're absolutely correct. Personally haven't been saved at least a thousand times!
  11. #86
    Quote Originally Posted by ebb
    I was real close to going with Mike G's FGCI epoxy, got a catalogue and even called and talked to them. But in the end, the ready availability of West won out.
    In retrospect, I suppose I'd rather my recore were delayed because I was waiting for a delivery of epoxy...
  12. #87
    Goo removed
    Not so bad really. The 25:1 ratio goo was basically resin and was nowhere close to hardening. I was able to just peel of the fiberglass cloth and biax strips I had laid down, scraped off what I could, then wiped it all down with acetone. I could have been a lot worse...
    Lesson learned.
  13. #88
    Talking pumping up the company
    Can get seduced by the local marine convenience store (WM.) Aside from ranting West Systems (Gougeon Bros) for foisting blush epoxies on the inexperienced, they do have packaging down pat. And they're the only act on the shelf. It is also true we are paying for the convenience of having the store down the street: taxes, morgages, salaries, utilities - that game forces the prices of everything up. (WM is a publically owned company and is probably worth more in real estate than inventory. Who knows what they're into. Who owns West Systems, for example? The CEO of WM makes a paltry million and a half a year. Good ole Empire building goin on heare!)
    For that little bit of wait you mention, online suppliers offer greater selection and better epoxies at half the price. The site I use sells 'marine' epoxies without the added surcharge. They are often what industry and the military use. The only problem I've found is eclectic containers. And maybe too large quantity. My white tank coating, for instance, requires a gorilla to open the plastic pail part A comes in. Decanting the thick creme into small batches takes invention and patience. What the hell...
    At least I'm not married to WM's consumeroid choice. Happy pumping!
  14. #89
    I know it's on this forum somewhere, but is this your internet site of choice Ebb? (http://www.epoxyproducts.com/)
    I'm sure I'm not alone when I say your well considered and thought out opinions weigh heavily when it comes to boat related decisions. You should work out deals with the companies you buy from and get royalties when a new customer says "Ebb sent me."...
    As for the re-recore progress: Saturday AM I rewiped the deck, then did some self appointed penance and reground the whole side deck to make sure no trace of my stupidity remained.
    Here's the latest picture. (Remarkably similar to a previous one I know - at least it's from a different perspective. ) But, I did manage a little happy pumping (and all of the batches hardened nicely) when I filled the forward stanchion holes with soaked biax and plenty of properly mixed and thickened epoxy, before Earnest made me relplace the tarp...
  15. #90
    Absolutely Gorgeous.
    It's definitely art.
    Those mysterious symbols....
    Interesting you've kept your core material
    a complete secret.
  3. Ariel #382
    By Tim61N in forum Gallery
  5. What would you do?
