And finally, the new core in place and weighted down. First, I wet out the lower skin and applied three fiberglass cloth patches to holes and thin spots, then spread thickened epoxy all over the bottom of the corecell pieces, mashed 'em down, wet out the undersides of the cut out deck pieces, spread thickened epoxy over the tops of the corecell pieces, then pressed everything in place, wiped off the squeezed out epoxy, laid down wax paper and put on the weights.
Next will be more grinding and scarf joints. Maybe 1/3 done. Then I'll have to make everything pretty again - grinding, fairing, grinding, painting...
