Results 1 to 15 of 348
Thread: Ariel #414
Threaded View
  1. #11
    Hey Mike, Guess you have to make up a proportion code sheet.
    Like 72 squirts part A / 14.4 squirts part B = 8 oz
    100 squirts pt A / 20 squirts pt B = 12 oz
    ETC
    Had to find a supplier for empty F-style gallon cans to screw in the pumps. Befor I nixed the pumps. But I got to like the wider mouth cans - you can look down the hole to see what's doin in there.
    I buy Part A in 5 gal bombs weighing 600#, it seems -so I have to decant with a funnel into smaller containers. No fun when the big one is full. I got a big mit and find it pretty easy to pick up a rectangular can by its side and tip it into the quart container - laboratory style at eye level one in each hand. Not you? You only need to have it half full, weight wise. Anyway you probably aren't set up for continuous use like 338 is.
    Spent an inordinate amount of time last few years with a gallon can in one hand and a quart container in the other. The wider mouth means that the syrupy epoxy pours out rather than BLOB - which indeed can get messy.
    Earlier threads point out that 2 to 1 and 1 to 1 epoxies are better to use. And easier to measure. One reason is that they are more tolerant of mistakes because they are essentially the same stuff in each container but one has the hardner. Been said these epoxies are in a premix state already on their way to set. Sometimes indicated by zero induction time. This might have been true yesterday, but today there are 100s of new epoxies!
    You're absolutely correct. Personally haven't been saved at least a thousand times!
  3. Ariel #382
    By Tim61N in forum Gallery
  5. What would you do?
