FS: A4, complete package
running when i pulled it out of the boat this past December, but could use new rings and honing of the cylinders for better compression. Last rebuilt by Moyer in '93. Raw water, but decent flow. I ran this engine all summer, about 20 hours, and had no issue other than oil pressure is a little low after the engine gets to temp. No knocks. Has new coil and distributer. I winterized by changing the oil, cleaned the carb, put a little MMO in the cylinders.
the package includes all additional running gear; 21 gal gas tank in very good condition, water lift muffler, fuel pump/filter, VDO gauges, 2 batteries (both newish, group 27), wiring with spark advancer, throttle/choke cables, transmission linkage and 'power stick'.
gas tank has 10-12 gal of good gas (november), so if you come down to pick up you have gas to get home!
500 bux. this is a pretty good deal even just for parts. located Tilghman, MD.
http://i1354.photobucket.com/albums/...ps00f2ecd4.jpg
http://i1354.photobucket.com/albums/...psfe0c105c.jpg
I sold the engine but the gas tank is still for sale
