2001 extrusion still exists
The good news is that the manufacturer still has the extrusions for our two weatherstrippings. The bad news is that the price has increased 17.5% and the minimum order has increased from 25 feet to 100 feet. Our original order was 186 and 300 feet of product that gave us approximately 50 sets of weatherstripping. It took five years to work off that inventory!
A quick check indicates that we can sell the kits for only about $4 or $5 more than previously. Our original price was $47 per kit, so the new price will be $51 or $52 plus shipping. (Maybe a little more for the Commander as its forward hatch is larger, but I need to do more research.)
Meanwhile, we need to hear again from those interested before expending something in the neighborhood of $1600.
5 Attachment(s)
I'll purchase enough gasket for ceili
Bill,
I'm definately interested in making a purchase for enough to redo Ceili's forward hatch and lazarette hatch.
Jerry,
I had to go confirm for myself (the measurements you provided from Destiny) and obtained the following from Ceili:
Forward hatch: 75-1/2" (6' 3-1/2")
Lazarette hatch: 116-1/4" (9' 8-1/4")
Total linear inches for both: 191-3/4" (15.979 feet)
The above dimensions have no additional length added for allowance of fudge or adjustment.
I too, would like a couple of extra inches to work with. I would think that the material (gasket extrusion) is bought and sold by the linear foot. With that being said, I would like to have 17 feet. (Jerry, same as your input)
Like Jerry, I was also under the impression the size (profile of the gasket extrusion) was the same for both hatches. Unfortunately I no longer have the forward hatch gasket that I removed from Ceili for reference. I do however, have the remnants of the lazarette gasket I removed and have attached photos of.
The lazarett gasket I have in hand (the old that was removed from Ceili) does fit on the forward hatch fiberglass lip just fine.
I would be interested to know the specific differences in the two profiles as indicated by Bill (referring to the original order that was based on the Ariel)
Bill: Do you have the profile dimensions of each extrusion that you make reference to?
Rico: You mentioned that you used the same (new) extrusion profile on Mephisto Cat. Do you have a piece in which you can obtain measurements (height and width), etc.?
So here is a little tidbit about the hatch gaskets on commanders....
When Bill was ordering the hatch gasket material for the association we had a discussion about the fact that both my laz and forward hatches had the same size gasket on them even though that is not what was standard.
Turns out the factory probably did that because when I put the standard size on the laz hatch fits really, really snug. It does not just drop into place you have to push it down to make it seat.
Just letting anyone who is planning on replacing their gasket know that they should check which size fits best for their boat.
