Mike, every thing looks great, one of these little engines popped up on Ebay with trans. and Instr. panel for a buy-it-now of $550 while I was thinking about and viewing your post on this engine, some one bought it. Are you satisfied with the power output of this engine? I would like a small light inboard with an alternator like yours or maybe even a 2 cylinder Yanmar. Happy sailing!
carl,
The Renault engine pushes the Ariel just fine. I had no problem motoring last weekend with the gusty winds on the Tennessee River. I don't have a tach, But I'm guessing the engine is running about 1500 - 1800 rpm when the boat is at 5 knots. It seems that 5 knots is the maximum speed it with go with this setup. That's with a my 13"x13" propeller. Seems like I remember reading somewhere in one of my books that the maximum speed of the boat under motor will be slightly less than the actual hull speed.
gimbaled stove
I just finished a gimbaled bracket for a Coleman 508 gas stove. Works great.
nice gimbal
and all aluminum
including the rod.
Really swings!
stove
The main part that the stove sets in was made from 1/4" 304 stainless rod. The end support was 1" aluminum tubing, the other support was a piece of teak.
Nice gimbaled stove prototype! You're about halfway to having a nice little side business. We're counting on you to get this economy moving!
coleman 508
For a 'review' of the stove see
google> Coleman 508 stove and carrier
By Seger 30 June 2002
The carrier is a aluminum cube with a tight fitting lid that can be used to cook with.
If these still come with the cannister, it seems like a good way to safely store the stove when not in use.
The cannister stove is reminisent of WWII GI stoves which Coleman made.
The 508 stove of course uses gasoline type fuels
Serger's review is a good intro into bringing it aboard the A/C.
Now that spriffy gimbal, where to get one of those?:cool:
__________________________________________________ __________________________________________________ ________________________
The best times past were with a Coleman two-burner with the lid and wings on the yearly camping trip.
A couple those models went to Yosemite as the kid grew up. A h h, those were the days!
google> Coleman stoves post - 1945
Coleman made alcohol and kerocene models, wonder what happened that they didn't continue?
Don't believe there is much of a problem coming up with Coleman fuel or white gas in the States.
I've a similar stove; the multi-fuel version that will burn Coleman, regular gas, or kero. Been planning this type of implementation. Did you do the work, Mike?
Yep, I designed and built everything.
Top view
A view of Schnell from the top of the mast.
Just looking at that picture gives me vertigo!
Gawd! These are great looking boats from every angle! I gotta ask though, how did you get that picture? Send the camara up with a timer? Did you just pull a still out of a video? I don't see any rigging for going up the mast or any feet pinching a toe hold...
top of the mast picture
Tony,
I took this picture by tying my Nikon D90 camera to the main sail halyard. I just wrapped a small line around the camera several times, with the lens pointing down. I focused the lens to infinity. Lifted the camera as high as I can, with a down haul line to keep the camera steady. Once the camera was at the top I took several pictures using my remote shutter release.
New Cushion covers
I just finished sewing new cushion covers. I made the bottom and the sides out of a marine grade vinyl. The top of the covers was made from a sunbrella that I ordered from sailrite.
Looks beautiful Mike. I like the vinyl for the bottom and sides, what kind of machine did you use?
