Sure, I have a harken 6:1 magic box near the end of the boom. I put a small block at the end of the boom. So the outhaul goes from the clew of the main, back to the end of the boom, through the block and forward on the boom for a few feet and terminates at the moving end of the majic box. To adjust outhaul tension, just pull onthe small line exiting the box, and voile' ...6:1 advantage and about 6" of adjustment range.Quote:
Originally Posted by c_amos
To cleat it off, I just mounted a small "lance cleat" (a wonderful little toy from RWO, you should check them out). I made sure to put the lance cleat far enough forward on the boom so as to be able to adjust it even when sailing on a run with the main let way out. But not so far forward as to need to leave the cockpit when sailing on a beat. I don't think I have a picture, but will look when I get home.
The small line exiting the magic box is plenty long enough to lead forward, down to some turning blocks and
