arguement for low-tech caulk
Just examined the Marshall Plan 'Hard Dodger Black-Out' tip again. Post #52
First thought is that if we are in a construction stage of building the dodger the black-out for the rabbet or the surround can be colored epoxy. If the color is mixed into thin laminating epoxy it can easily be painted on with a small brush.
When you are doing the final dry fit and have the plastic window with its protective covers still on and it's fitted and snug in place over the openings - why not carefully score the protective sheet using the edges of the opening inside as the guide. Probably an Xacto knife using a flat round tip blade to track easy.
Steve is saying to make the cut 1/64th of an inch inboard of the edge. Not sure why.
Like Steve says: after dry fit you take it apart, peel-off the edge ribbon of protective sheet and scuff the rim where you want the goop to stick. The sil-thane hybrid probably says you don't have to prep the surface. I'm still of the opinion that this installation doesn't need to be structural with everything bonded into a monocoque. The plastic lights will have to be replaced sooner or later down the line. Installing it onto a less aggressive caulk or tape might still keep the water out - or keep the water out WELL ENOUGH - and make it easier to take apart later. Call it a gasket.
The problem is: that 7 years later the tube caulk you used will be as hard as a rock. And replacement of the plastic windows will look like a federal case. So it IS a no-brainer that you choose the new hybrid (locally it's LifeSeal) which promises long life flexibility with excellent UV and ozone resistance. Problem is: it's also an excellent adhesive.
__________________________________________________ __________________________________________________ ________
Or see it as a maintenance issue and use butyl. The butyl tape readily available from Copperstate Roofing Supply
http://www.bestmaterials.com
comes in various but limited thicknesses and widths. I chose 3/32"X1" at $5.35/50' roll with a paper release - because my flanges are 1". It's gray.
Available from McMasterCarr, pg 3361, Butyl-Rubber Sealing Tape. Black and 1/8" thick and only comes in 1 1/2", 2 1/2", and 8" widths. The 1 1/2" is $22.74 for 48'. Too wide for most overlaps and flanges. However it's readily cut with a putty knife and a straight edge*. If you press down on the wstraight-edge when cutting you'll get a preview of its stickiness. Both tapes are tacky on both sides, very limp and conformable. Can tease the width of it around a radius. Have to cut it for corners, but you can smooch it together for a seal.
Doesn't smell nor come off on the hands. There is no interior core like some glazing tapes have, so you can pull it out of shape. The stuff is legendary for staying pliable, supposedly gets stronger the older it is, and has similar UV and ozone resist to the hybrid silthane. It is also conceivable that the material, having no core can squeeze out under fastening pressure and over time. Having equal torque on all the fastenings probably keeps it stable.
Don't know that anybody has reported what it's like taking butyl-taped glazing apart after seven years in the tropics. Have to assume though that it's going to be an easier job, than the hybrid or p.sulfide, prying the glazing off and scraping out the rabbet. It's a gum-like caulk not an adhesive. I'm also using it for the cabin windows. And thinking about putting the hatches and dodger on with the stuff.
*On a slab-on ap, where the windows are not in a rabbet, the too-wide tape could be used anyway and carefully trimmed with a new blade after it's all together? Might work same way with a rabbet installation by merely trimming the too-wide away inside with a knife after its done? It's clean stuff, the tape, no solvents. The putty knife is used to 'separate' squeeze-out from embedded stuff. Silicone coated kitchen implements can be used, if you find the shape you want.
The tape is very sticky but in a wad can be used to clean up a surface of butyl tape pieces and smears by pressing the wad on it.
Butyl tape with a strip of material inside the butyl can be found. I would not use this stuff if you are depending on squeeze-out to create your gasket. Cleanup would depend on cutting the embedded fabric - which would be hard to do because you can't really draw a sharp knife through butyl with success.
[McMasterCarr are the quickest but often not the cheapest! In talking to self here see clearly now that the way to go is with the 1/8" black stuff. And after the installation is complete trim off the excess. Think better in 1/8" rather than 3/32"!]
[WAY LATER EDIT: Control squeeze out of butyl tape by inserting a washer into the tape over each fastening before you put the fixture or lens on the cabin side or deck. The washer's thickness will prevent total squeeze-out when tightening up the window, plate, or base.]
In the wet installation:
The foam rubber dam probably got glued to the tube supergoo. It MIGHT be persuaded by passing the same Xacto blade between the foam and the edge of the rabbet.
imco - no dam butyl ebb
"Go easy, if you can't go easy, go as easy as you can." radio sign-off by Jennifer Stone
A designer's advice (filtered thru a curmudgeon)
Mike, nice addition here.
Just for argument, the photo sez: Definitely homebuilt, DIY.
Nothing wrong with advertising homebuilt, Some designer pointed out that when making these additions the sight-line of the appendage should point to the stem fitting. They should tilt forward, if they are tall enough. I've noticed that this is good advice for hard dodgers that often make a boat look like it has a pilot house. Or extra cargo.
Soft dodgers which USUALLY don't confuse the boat's lines are often horizontal topped. But then the eye gets a discount when pram dodgers are a darker color than the boat. When in doubt, paint ANY dodger a darker color.
A hard dodger is the most difficult thing to add to a sailboat and make look acceptable. Some boats make it into the character stage where the skipper's personality tops the boat's and the amalgam is completely happy, or otherwise. Usually the color scheme is the give-away. There are boats that are too small or too large to obey this tradition.
Anyway, that the top of the dodger or any other large addition to the exposed deck/sheer of a boat, lines up with the deck at the bow, is a place to start from when designing something the critical eye will accept. Easy as drawing a line on the elevation plan to check it out.
imco It's a reasonable aesthetic that takes into account windage, greenwater and design. Streamlining tells a lot about a fish's lifestyle. Or a boat's, for that matter.
From that datum you makes your compromises.
Downloaded an early '80s blackandwhite Cape Dory Yachts intro brochure listing all of their Alberg C.D.s.
Definitely designed to be a family of yachts, they each have features that every other has. Except maybe for the babys: the Typoon Daysailer and Weekender have the rounded rudder profile of the '60s A/Cs. The whole line sports the familiar full keel, soft cutaway forefoot and 'Constellation rudder'. (The babies might run aground alot - a round bottom rudder would be easy to get unstuck in mud, while a straight bottom constellator might be difficult to move.)
The no-doghouse coach roof in every case parallels the waterline emphasized with a trimline of teak over rectangular rounded portlights. Club foot jibs are featured. The larger yachts in the line are doubleheaded with short bowsprits.
None of Alberg's designs that I've noticed have shown even a hint of hard or soft dodger, or runabout wind-screen.
Maybe his later boats? I would have liked to see what the master would do with a dodger.
