Look at the bright side!!!
Willie
From the pics you posted I don't know how you'd get it out without; 1)removing part of the the sole or B)busting the concrete into velveta box sized chunks. (Spam can sized chunks naturally would work also) This one is a real b!#@%. Feathers and wedges would work if you had access to the top. If you could lift it even 1/2" and slide some ply scraps or absorbing shims of some sort under it you could even buy a little freedom on the sides as it lifts out of the taper of the bilge. Sometimes its best to let things sit for a while and work on another boat project until it hits you or just drives you mad:D 200 pound! Must be alot bigger than I thought. Tony G
ANOTHER PROBLEM WE FOUND TODAY
Hey, the Skipper Jr. pointed out a problem he has with his boat this morning. So we're running late on 350. Thought you guys might be able to help. I told him sand it down, then epoxy barrier coat. Wadda ya think?:D
